Turn signal dash light
Have a troubleshooting question for the turn signal indicator on the dashboard.
I have a 65 F250 with the custom cab instrument cluster. Until yesterday, the single green blinker would blink for both left and right turns. Now, it only blinks for left turns. When signaling for a right turn, I can hear the flasher clicking, and indeed, both the front and rear exterior turn signal lamps are working. But the blinker on the dash does not flash. When turning left, it does.
Is it the case that there are two lamps that share the same green blinker and one is dead? Or is it a problem possibly in the flasher relay itself?
Separate question: does the turn signal automatically cancel on these trucks? Mine has always required manual return to the middle position, but not sure if that is by design or if something is broken.
Thanks
Thanks
Thanks
Thanks
00Expo&73Bronco
1997-2006 Expedition & Navigator
07-18-2003 08:55 PM
8ntractorman
02-16-2003 02:24 PM
