I replaced my bulbs today to fix a few turn signal/brake lamp problems.
They are all fixed save one. My left front turn signal does not light when turned on by the turn lever. It does work fine for the running light and also works for the hazards. The interior dash indicator does not work either when trying to use the left signal, but works fine with the hazards. Left rear works correctly.
Sounds like the whiskers on the turn signal cam are bent/damaged. It's difficult to get to, and even more difficult to explain, but you can find a cruddy aftermarket Motormite HELP! replacement cam at most parts stores and look at it. The instructions on the back give an indication of what a pain it is to do, but the $130 for the Ford replacement turn signal switch assembly may make you go for the HELP! part. Expect it never to work like the factory one.
Some diagnosis may prove another source for your problem, though.
Had the same problem with my truck, pulled the steering wheel off, took out the one screw that holds the turn signal cam and saw that one of the whiskers was bent. Straightened out the whisker and has been working perfectly ever since... Autozone will lend you the steering wheel puller to help do the job.. It was an aftermarket switch that I had bought from napa.
8n
Can you picture a cam with a spring hook on each end, 2 wire whiskers that span it, and a wire riveted to each whisker? Then try to picture it resting in a pocket with a flat spring pressing on 2 tiny posts to hold it straight, but 2 pegs to catch the 2 hooks when it's turned, and like 6 contacts for the 2 whiskers' 4 ends to wipe across.
I'll put this on the "to do" list after I take out the new oil pump I have in my new motor in my Mustang that has 300 miles on it. Gotta love bad parts. Ugh!
OBTW, love your site. Great info there. I bookmarked it for future "projects".
ditto on the "great threads!! Learning new things everyday..."
comment above. I am grateful to the people who make this forum work.
I had the same problem on my 91 E350, and used the HELP! replacement cam ($10 ).
I had to file a bit on the new part to get it to work, and the crimp- on connectors into the wiring failed after a few days, had to remake the splice with solder and heat shrink tubing, but it does work.
