where is it?
Old Jun 27, 2015 | 07:20 PM
fdude64's Avatar
fdude64
where is it?
So today i cleaned my ebps,tube and fittings. The fitting in the bracket was plugged solid. Got that opened up and the tube cleaned out. My real question is where is the exhaust back pressure valve? Is it the butterfly valve on the turbo? And what would happen if i unhooked the vac.line to it?
Old Jun 27, 2015 | 08:03 PM
fdude64's Avatar
fdude64
Oh yea forgot to say it is a 2000 f350 sd with a 7.3 diesel
Old Jun 27, 2015 | 08:25 PM
Thomas White's Avatar
Thomas White
Its at the base of the turbo. You can disconnect power from it by removing the connector at its base in the front. You'll have to lift a wire retainer which maries the two connectors. There is no "vacuum line". Its an electronically controlled valve which activates as determined by PCM inputs,
Old Jun 28, 2015 | 08:43 AM
Tugly's Avatar
Tugly
The "vacuum" line is the red pressure line to the wastegate control - different beast. The EBPV is oil powered, and the wastegate releases with a combination of control from the red line and spring pressure on the valve. removing and capping the red line is a common mod to get more boost, but the spring still releases boost into the exhaust when it reaches a set point.
I set my wastegate to release at 35 PSI boost. I can surpass that, but then I'm sneaking up on straining my tired valve springs - risking profound havoc under the hood.
Robert6401
22
Oct 28, 2010 08:20 PM
rps58
Oct 16, 2007 07:50 PM
ecrailings
Sep 26, 2006 09:55 PM
btak
Jan 19, 2006 10:40 AM
spitball
Jul 30, 2004 04:35 AM
