What exactly does unplugging the wasegate do??
Old Jul 29, 2004 | 02:36 PM
spitball's Avatar
spitball
I read in a earlier post that unplugging the wastegate and sealing the tube off creates more performance. Just wondering what the theory is behind this and how it effects flow and performance. Thanks.
Old Jul 29, 2004 | 05:04 PM
wlihntr's Avatar
wlihntr
the wastegate is a pressure relief valve on the turbo charger, that red line on the actuator is a vaccum line that the computer sends a signal to so it will open the wastegate to let boost pressure out. the computer is programed for safty not performance so it will open it well before max boost is reached. buy unhooking it and plugging you can slowdown when it opens and make a little more boost(power). the wastegate also has a spring to open it which also can be modified to make even more boost
Old Jul 30, 2004 | 04:35 AM
spitball's Avatar
spitball
Thx for the reply. I just put a new turbo on mine, and have been hovering around the idea but unsure.
