Ebp
Old Jun 23, 2015 | 11:53 AM
bizzelj's Avatar
bizzelj
Ebp
Hey guys just wondering if an 04 ebp sensor and tune will fit an 05?
Old Jun 23, 2015 | 12:00 PM
npccpartsman's Avatar
npccpartsman
Sensor probably will but the tune, no.
Old Jun 23, 2015 | 12:07 PM
WatsonR's Avatar
WatsonR
The sensor is for 03-07 I believe, just located in a different spot. Probably not many who have taken the sensor from an 04' and put it on an 05', but it should work.
Tune should be good, unless they are written specifically for a strategy.... and the same modifications from truck to truck, stock-stock. You don't want my tune, its a studded tune, I'd be pretty careful here, unless it's your truck its coming from and you know wheres its going too.
Old Jun 23, 2015 | 01:03 PM
bizzelj's Avatar
bizzelj
Sorry guys I meant tube
Old Jun 23, 2015 | 01:08 PM
bizzelj's Avatar
bizzelj
The reason I ask is because someone on here has an 04 ebp sensor and tube he doesn't need and I need a new one
Old Jun 23, 2015 | 01:36 PM
WatsonR's Avatar
WatsonR
the 04 tube and sensor are mounted to the t-stat housing. The 05 goes just under the degas tank. If the connector reaches, you could probably just bend the tube to fit, but don't bend it at a sharp angle and fold the tube shut or put a kink in it that could lead to a cracked tube. Should work fine.
Old Jun 23, 2015 | 04:12 PM
bizzelj's Avatar
bizzelj
Well since it's just a tube I should be able to reuse the one I have right and just use the 04 sensor
Old Jun 23, 2015 | 04:37 PM
evan1242's Avatar
evan1242
should be able to, just clean it with some weed wacker string first.
wedge542
May 8, 2025 09:04 AM
wingrider75
Sep 2, 2014 01:24 PM
JR2980
Jul 23, 2012 12:01 PM
marcussen
Sep 22, 2007 04:32 AM
