Vacuum Pump Interchange?
Old Jul 4, 2015 | 02:30 PM
madpogue's Avatar
madpogue
The belt will NOT clean that up. We let the one on our blue truck get that way, from sitting for a couple months. The belt did NOT clean it up after driving it, it only turned the green-back belt brown with rusty gunk. I pulled the belt, spun the pulley and cleaned it up with a vibrating sander (80, then 240), then finished up with an old green dish scrubber. Did the same with the smooth idler on top. THEN when we drove it, the cleaned-up pulleys cleaned the gunk off the back of the belt.
Old Jul 8, 2015 | 01:11 AM
Spktyr's Avatar
Spktyr
Confirmed - 96-97 pump *does* bolt right up and work correctly on the 95 motor. It's also significantly cheaper and more powerful so there's no reason not to do it.
Possible Tech FAQ post item?
Bearhugger1933
Feb 3, 2016 07:17 PM
endobear
17
Apr 8, 2014 09:49 PM
86f250XLT-4x4
Jul 3, 2013 08:46 PM
resonance530
Jul 26, 2006 09:23 AM
