96 F350 PSD E4OD Transmission & F5TA-DA Transfer-case swap into 97 E350 PSD?
Hi All,
I've located a E4OD/F5TA-DA from a 96 PSD F350 for sale on CL that I'd like to buy & swap into my 97 PSD E350 to transform it into a 4x4 van. Both van's & donor E4ODs have a '27' stamped into top of case near bell-housing. I believe from research that the van's 7.3L PSD is a small block & would guess that the F350's was not. Will this swap succeed or are these components not interchangeable? Thanks in advance for any & all comments, advice, & guidance!
Hey waitaminit - we have a whole SECTION dedicated to the bread-boxes here on FTE -- 1968-2013 Full Size Vans - Ford Truck Enthusiasts Forums . Bet a nickel and an old rusted doghouse bolt that someone over there has done it, or owns a conversion, or what-not.
Thank-you for your response, Mark Kovalsky... Your expert opinion was what I was looking for.. & thank-you madpogue I will look there to see what I can find. Among the bullet points you posted, 1 stands out as unknown for me. Will 97 7.3L PSD E350 PCM command a 96 7.3L PSD F350 transmission to shift & operate properly or require mod to be compatible? An electronic ratio adapter will be used to spoof PCM into accepting pulse driven VSS signal vs. gear driven that it is looking for so it will accept shift points in 4L. The axles & suspension were pulled from a 04 6.0L PSD Excursion. Front axle is a Dana 50 & rear is a 10.25 Sterling. The front leaf springs that came with D-50 wont bolt up to van natively but biggest obstacles as far as fitment of things underneath are van's driver side framerail mounted fuel tank & engine crossmember. The fuel tank is too long for transfer case to fit & engine crossmember doesn't clear D-50 differential. The polypropylene fuel tank from Excursion will move in where spare tire used to live in back of van so framerail tank will be retired. A skid plate will be fabbed to cradle it back there. Transmission crossmember will be lengthened to accomodate transfer case. Engine crossmember will require a 1" trim across driver's side beam to clear diff & front driveshaft.
Ford4Life7.3
08-19-2013 03:37 AM
Paul curtis
07-24-2011 01:16 PM
armstrongfordtrucks
07-11-2010 03:47 PM
