hvac vacuum pump woes
Old Jul 25, 2006 | 07:52 PM
resonance530's Avatar
resonance530
Alright, I traced out all the vacuum lines and they're fine. I checked all the fuses under the dash and they're fine. When I pulled the vacuum line off the pump my highly scientific method of sticking my thumb over the port to feel for vacuum led me to believe the vacuum pump was dead. I found service bulletins saying the stock pump would die pretty commonly. SO, I assumed my pump was dead, went to the ole' dealership, paid msrp because it's 110 degrees here and didn't want to wait for shipping, got home, installed the new pump and...NOTHING! Still defrost vents only, still no vacuum at the pump. $135 wasted. What am I missing?! Which fuse powers the pump? They're all fine under the dash, but could it be a relay or something else under the hood? I'm so freaking hot.
Old Jul 25, 2006 | 07:56 PM
clux's Avatar
clux
I guess i't first try to determine if it is an electrical or plumbing problem.
Is there power to the pump? You should hear it run when you first turn he key on.
Old Jul 26, 2006 | 09:23 AM
nodakford's Avatar
nodakford
Pull the vac line from the pump to the reservoir. The pump will come on. Then stick your finger over the open port and th pump will turn off. If not check for power at the pump.
capriceragtop
Oct 3, 2013 05:51 PM
ddiercks
Jul 13, 2013 06:00 AM
daverous
May 12, 2010 10:19 AM
v8only
29
May 7, 2007 05:33 PM
bluneon
May 2, 2006 10:51 PM
