rear axle sensor and plug
Old Jun 19, 2015 | 10:04 AM
tomfiii's Avatar
tomfiii
Just replaced my rear axle speed sensor and repair plug and now light is flashing on and off and that's why I replaced items from just less than 2 years ago replacements on my 1999 super duty. Is there a problem with these replacement parts ,is there any tricks to this???
Old Jun 19, 2015 | 02:07 PM
Franklin2's Avatar
Franklin2
Take it somewhere and get the codes pulled to make sure you have a speed sensor error.
Old Jun 19, 2015 | 03:01 PM
tomfiii's Avatar
tomfiii
The codes are not the problem! I am loosing the connection momentarily. Before I would have to wiggle plug at connector to get ABS light to go out and then I fooled around with pins in sensor and it would still go on and off. The new set causes light to flash on and off causing shifting problems also of course. I need to know what can be done other than cutting end off of sensor and hard wiring it!
Old Jun 19, 2015 | 07:41 PM
Franklin2's Avatar
Franklin2
Autozone sells the connector. $11.99 part number 597
Old Jun 20, 2015 | 02:14 PM
tomfiii's Avatar
tomfiii
Just replacing the connector again is no guaranty it will fix it.
Old Jun 24, 2015 | 05:33 PM
tomfiii's Avatar
tomfiii
Update ,found problem in crimp ,removed crimps and soldered connections. Still loosing connection intermittently,wiggle connector at sensor and it worked for a day or so.
Old Jun 30, 2015 | 10:30 AM
george87's Avatar
george87
For sensor problems if the sensor itself is not faulty, the culprit would be the wire. Loose connection will increase the resistance of the line your sensor is connected to resulting to erratic readings. Try to rewire the sensor line.
Regards,
George S.
http://blog.7pcb.com/
Old Jun 30, 2015 | 11:06 AM
tomfiii's Avatar
tomfiii
Regards,
George S.
Blog - Bittele Electronics
That is the problem ,how do you tighten the connection at the plug and sensor.
Old Jul 8, 2015 | 06:11 AM
JWA's Avatar
JWA
If the connector is loose then replacing it with a repair-oriented is the only option. IF the sensor receptacle is the cause of the connector being loose then it needs to be changed too.
Sometimes one or both parts of an automotive type electrical connector can be the cause of intermittent loss of continuity.
Ford_F350SD
Jun 14, 2013 03:20 PM
ronjon95
Feb 26, 2011 08:26 AM
purecty
Apr 15, 2008 08:02 AM
tobyw
Aug 14, 2007 11:00 AM
Brizzadd
1978 - 1996 Big Bronco
May 12, 2003 08:13 PM
