1978 - 1996 Big Bronco
Vehicle Speed Sensor/ Rear ABS Sensor
Old May 11, 2003 | 12:53 PM
Brizzadd's Avatar
Brizzadd
I just broke the plug that is mounted to the top of my rear differential off of my 96 EB Bronco. I posted my predicament here to no avail. I was told that this plug is the rear ABS sensor or the Vehicle Speed Sensor. With that in mind I found a local parts store that had them in stock. When I got there, upon comparison I found that something was wrong. The new sensors they were showing me were twice as big and had some sort of additional plug on it for something else. They were also metal and twice as long. My original consisited of a single plug with a inch long plastic thing that goes inside the diff. Can anyone tell me what this thing is? I tried to drive the truck with it broken and the ABS light comes on, the overdrive "off" light flashes and the truck doesn't shift out of first.
Old May 11, 2003 | 07:22 PM
bigric's Avatar
bigric
That's still the vehicle speed sensor you're dealing with; that's the only plastic thing that goes on the differential. If the parts house had something odd-looking, try your Ford dealer tomorrow; you're guaranteed to get the right part.
When I looked it up on AutoZone for you last night, there were several listed for your vehicle, and they were all different from the one I put on my '92. But they're still all vehicle speed sensors.
Old May 12, 2003 | 06:25 PM
Red_EB_Bronco's Avatar
Red_EB_Bronco
yeah, my "rear anti-lock" light is on! is that because of a faulty ABS sensor? if so where would it be located! and how easy is it to replace
Old May 12, 2003 | 08:13 PM
steve83's Avatar
steve83
The Haynes manual tells how to pull RABS, RABS-II, & 4WABS codes with a jumper wire. The sensor is in the top of the diff, like he said in the first post.
pawpaw
1983 - 2012 Ranger & B-Series
48
Mar 26, 2023 11:28 AM
CBRR
Aug 15, 2016 05:08 AM
JustFixIt
Aug 5, 2015 04:21 PM
zrt600guy
Feb 14, 2012 04:10 PM
magneto259
Aug 10, 2009 06:37 PM
