Another dumb tailgate question...
Old Jun 18, 2015 | 06:06 PM
jco69's Avatar
jco69
ok, i consider myself pretty mechanically inclined, but this tailgate is driving me nuts! do the hinges go in the gate first, the "slide" the gate in then bolt it down? do the supports have to be off first?
Thanks in advance, and sorry for the dumb question.
John
Old Jun 18, 2015 | 06:34 PM
resonateur's Avatar
resonateur
John:
My recollection, just removing the gate a couple months ago...
Place pivots on pins and slide into proper position starting at a slight angle. Hove someone support the tailgate and bolt the pivots to the bed.
Place hangers on keyways and rotate them to proper position while someone supports the gate. Bolt hangers to the bed.
Someone will correct me if that's not the way....
Old Jun 18, 2015 | 06:45 PM
41505379's Avatar
41505379
Tailgate pivot. I have an old Ford pickup trailer of your vintage. The previous owner cut the bottom of the pivot off one side of the tailgate. This allows for easy removal and replacement of the tailgate. This has been VERY HANDY over the years.
No one would ever want to steal my tailgate, so I still have it.
I would think that with an intact tailgate you would slide one end onto the previously bolted on pivot and then put the other pivot into the other end of the tailgate and figure out how to bolt that pivot onto the body.
Or trim the bottom of one end of the tailgate like my PO did.
Patrick
Old Jun 18, 2015 | 07:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4TZ-9940700-A .. Styleside Tailgate - Has large FORD block letters - 1964/66 F100/250 2WD & 1966 F100 4WD
9/1966: Ford replaced C4TZ-9940700-A with C7TZ-9940700-A .. 1967 (1967/72) F100/350 Styleside tailgate (has smaller FORD letters surrounded by a raised ovate scallop line) for use as a "service part replacement."
ALL the mounting hardware and the tailgate handle is the same for both these tailgates. The tailgate supports (aka 'scissors') were also used on the 1973/79 F100/350 Styleside tailgate.
Old Jun 18, 2015 | 08:01 PM
jco69's Avatar
jco69
thanks guys, ill have to mess with it some more tomorrow. already thought about cutting one side, 86-92 (i think) gates have one side cut from factory
Old Jun 18, 2015 | 08:04 PM
jco69's Avatar
jco69
Old Jun 18, 2015 | 11:15 PM
resonateur's Avatar
resonateur
If yours is a 92-96 it will go on that way...I'm assuming in this forum...its considerably earlier. You shouldn't have to cut anything...Ford put it together without doing that...
Just get a second pair of helping hands.
Old Jun 19, 2015 | 07:53 AM
jco69's Avatar
jco69
no, mines a 66. i just assumed thats how all tailgates went on, it would make on/off alot easier....
Becky_is_a_66
Apr 16, 2019 07:53 PM
droppedf100
WTB - Parts & other
Feb 20, 2018 07:18 PM
Claybreaker144
1961 - 1963 F100 Unibody
Jan 28, 2018 08:58 PM
good to doo
Apr 10, 2017 02:27 PM
