Pulling IDI and 4eOD; suggested sequence
Old Jun 17, 2015 | 05:48 PM
irhunter's Avatar
irhunter
So, my plan was: put jack under rear of motor, pull tranny, lift motor, pull frame out from under motor.
But, now I look under there and I don't see anywhere to jack the back of the motor. It seems all there is is oil pan and transmission.
So, suggestions for a sequence of pulling would be appreciated.
I am trying to avoid lifting the motor and transmission together for weight reasons. I was going to use the engine hoist to pull the transmission.
Thanks,
Roy
Old Jun 17, 2015 | 09:41 PM
Macrobb's Avatar
Macrobb
If you've got a decent jack, take it and place it under the oil pan. Put a block of wood with a cutout/depression for the drain plug on top of the jack, and you can level the engine a bit that way.
Really, the engine is fairly stable with just the two side mounts; it will sit there(angling backwards quite a bit) if the transmission is removed, so all you need to do is lift a little bit to keep it square - you can almost tilt it back and forth by hand.
Old Jun 18, 2015 | 07:07 AM
irhunter's Avatar
irhunter
Right. Thanks.
Yes, the motor has the look of being pretty balanced with its side mounts.
Roy
Old Jun 18, 2015 | 11:20 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Jack the motor up enough to get something under the tranny from leaf spring to leaf spring. set it back down until the tranny is supported, then separate them. FYI, a dressed IDI is in the neighborhood of 1300 lbs.
Old Jun 19, 2015 | 09:24 AM
irhunter's Avatar
irhunter
Thanks. Yes, I know they are crazy-heavy. I have a 2-ton hoist...but, I have no faith in the weight ratings attached to low-end hydraulic products. We'll see how it goes.
Roy
Old Jun 19, 2015 | 01:49 PM
hairyboxnoogle's Avatar
hairyboxnoogle
This really makes me appreciate having access to a loader. FWIW, your 2ton hoist will lift them both fine. Use the engine lift points, with a ratchet strap on the trans to level it.
Old Jun 19, 2015 | 02:11 PM
irhunter's Avatar
irhunter
Oh sure, rub it in...
Loader, fork lift, back hoe...I have none of that.
Yes, I'll use the three factory lift points plus one I added. I will, however, yank the transmission first. 2 tons seems way over-kill, but I have had had 2-ton floor jacks which could just barely lift one front wheel on these diesel trucks.
When it's all over, I'll report back.
Roy
Old Jun 19, 2015 | 02:29 PM
sjwelds's Avatar
sjwelds
Loader, nothin'. Overhead electric and/or chain hoist FTW!!
Old Jun 19, 2015 | 05:07 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
how about one of these?
Old Jun 19, 2015 | 05:16 PM
sjwelds's Avatar
sjwelds
^^^ Yeah! Hey if you took the hood off and had a big stack of batteries you could pull your truck's engine with it's own crane! How cool of a youtube video would THAT make??
Old Jun 19, 2015 | 05:20 PM
FORDF250HDXLT
hahaha! no need for a big stack of batteries.i ran heavy cable the whole length of the truck.she stays fully juiced with the truck running.
edit! oh duh.if you wanted to pull your own engine though.yeah.sorry.long day......long week!
just park another vehicle at the back battery (where there is a now a under body toolbox for a battery) and just run jumper cables........but to pluck an engine out,she wouldn't even run the battery all the way down.i was able to load a few logs before i knew i had to run a cable to keep her fully charged.
but this truck is so long,i don't think she'd reach to pluck her own engine though anyway lol.
85AustinTucker
Jul 26, 2015 02:20 PM
Ole' gray
Feb 14, 2012 07:56 PM
4x4jedi
Jul 19, 2010 08:55 PM
Thomsen
Offroad & 4x4
Jun 3, 2005 02:47 PM
jevanof
Feb 11, 2002 02:53 PM
