High Output Alternator Problem DB Electrical
Old Jun 27, 2015 | 08:39 PM
  #46
valutechpc's Avatar
valutechpc
I've taken this alternator off about 10 or 12 times now. Well not this one but several replacements and to change voltage regulator etc. I'm a pro now. Can do it in 7 minutes.
Old Jun 27, 2015 | 10:09 PM
  #47
agsmv1's Avatar
agsmv1
So how does it run? does it charge up the batteries? You do know at idle you will not see 220A even at full load conditions. At idle I see about 12.5V and don't actually hit +14V till I get moving.
Old Jun 28, 2015 | 01:09 AM
  #48
Gmcbuffalo's Avatar
Gmcbuffalo
What is the heavy fused cable battery bypass? I have done #3 and will do 1 and 2 when I get home. Confused on #2.
Old Jun 28, 2015 | 08:25 AM
  #49
LivingLarge's Avatar
LivingLarge
Originally Posted by Misky6.0
Ed @ FICMrepair.com makes and sells upgrade battery and alternator cables.
1. Add a heavy cable alternator to ground.
2. Add heavy cable w/300 amp fuse alternator to pass battery.
3. Add a heavy cable between pos terminals of batteries.
These reduce resistance between key components of electrical system to maximize charging and reduce voltage drop.
Misky6.0 posted this earlier in the thread.
# 2 is if you have a diesel with 2 batteries.
Restlesswildman
Feb 8, 2013 09:01 PM
Eric_F250
Feb 7, 2009 08:35 AM
EMSRanger97
1983 - 2012 Ranger & B-Series
Jan 22, 2008 08:50 PM
ScottJM
Jan 10, 2005 02:25 PM
karljay
Aug 9, 2002 03:40 PM
