High Output Alternator Problem DB Electrical
Old Jun 17, 2015 | 08:57 AM
valutechpc's Avatar
valutechpc
Originally Posted by agsmv1
What is your voltage once you start driving around? Like I said, mine starts off low then eventually settles at 14.45 once I actually get going.
-Art
It's in the 13's. If I stop at a red light it drops down to 12 something.
Old Jun 17, 2015 | 09:10 AM
LivingLarge's Avatar
LivingLarge
That's just to low, I still think it's the voltage regulator... Specially in your case with the 6.0, you can start damaging the injectors.
Old Jun 17, 2015 | 09:16 AM
valutechpc's Avatar
valutechpc
Yea, and I just put 8 new injectors in about 4 months ago. And occasionally get a cyl 5 contribution code now.
Old Jun 17, 2015 | 11:54 AM
agsmv1's Avatar
agsmv1
Yep, that's no good. I only see in the 12's right after startup then it quickly jumps to 13.X and eventually settles on 14.4.
-Art
Old Jun 17, 2015 | 12:06 PM
valutechpc's Avatar
valutechpc
I'm thinking they sold me a 160 amp version instead of the 200 amp.
Old Jun 17, 2015 | 12:17 PM
harley4jcs's Avatar
harley4jcs
No markings Are you still waiting on there call back
Old Jun 17, 2015 | 12:35 PM
LivingLarge
Even if they sold you a 110 it should not be at 12 anything when idle
Old Jun 17, 2015 | 01:05 PM
valutechpc's Avatar
valutechpc
There are some numbers/letters etched in the top. They said those numbers don't mean anything to them. There are no other markings.
If I had a 110 amp version but the system was drawing 160 amps, wouldn't the voltage keep dropping?
Old Jun 17, 2015 | 01:16 PM
LivingLarge
Yes, but a normal working alternator even a 110 amp, with let's say lights and ac on should be in the 13's even at idle not 12 anything.
Old Jun 17, 2015 | 01:19 PM
LivingLarge
My oem averaged 13.4- 13.7 under the load I just mentioned. My new alternator once the truck starts it sits at 14.4 with ac and lights on.
Old Jun 17, 2015 | 03:07 PM
agsmv1's Avatar
agsmv1
Mine eventually settles at 14.2V. Now regardless of the 160A or 200A version their website states the VR is set to 14.5V so even if they sent you the wrong one your voltages should be higher especially after you drive around and charge your system back up.
Old Jun 17, 2015 | 07:24 PM
valutechpc's Avatar
valutechpc
Here's some more interesting information. My voltage actually goes up as soon as I turn the key off.
Old Jun 17, 2015 | 07:51 PM
  #28
LivingLarge
If it was me, I would check and clean ALL battery cables than I would have the batteries load tested. If those would pass, I would throw that alternator in the trash and move on.
Old Jun 18, 2015 | 02:38 PM
  #29
valutechpc's Avatar
valutechpc
They finally called back and said that the voltage is definitely too low and to send it back to them. Today I went out to start the truck and the battery light stayed on. No output at all. Sounds like I just got a defective unit. I will post again when I get the new one. Thanks for the suggestions.
Old Jun 18, 2015 | 03:02 PM
  #30
LivingLarge
Have you done the big 3 upgrade to your cables? If not this would be a good time.
