Hydroboost Upgrade
Their Ford C-2 PS pump was plumbed for two return lines.
The rebuilt PS pump can be had from O'Reilly Auto Parts for $47.00 plus a $5.00 core charge.
MasterPro Power Steering 711-2113 - Power Steering Pump | O'Reilly Auto Parts
The dimensions of the bolt holes in the firewall are 3-1/4 x 2-1/8 and the opening is centered on the lower bolts. I decided to lower my hydroboost bolt holes by 1/2 inch so that the bolt heads would not be right up against the widest part of the hydro-body. Since the pedal linkage can move up & down this 1/2 won't affect it at all.
<a href="http://s1020.photobucket.com/user/crazycracker289/media/F-100/69%20F100%20Brake%20Upgrade/IMG_0286_zpswhf68hxl.jpg.html" target="_blank"><img src="http://i1020.photobucket.com/albums/af330/crazycracker289/F-100/69%20F100%20Brake%20Upgrade/IMG_0286_zpswhf68hxl.jpg" border="0" alt="Redrill the Hydroboost Bracket photo IMG_0286_zpswhf68hxl.jpg"/></a>
Redrilled hydroboost bracket. The bolt size is 3/8 but I made the holes larger so that I have some "wiggle room" in case my dimensions are not perfect.
<a href="http://s1020.photobucket.com/user/crazycracker289/media/F-100/69%20F100%20Brake%20Upgrade/IMG_02911_zps1cptbrm1.jpg.html" target="_blank"><img src="http://i1020.photobucket.com/albums/af330/crazycracker289/F-100/69%20F100%20Brake%20Upgrade/IMG_02911_zps1cptbrm1.jpg" border="0" alt="Hydroboost Mounting photo IMG_02911_zps1cptbrm1.jpg"/></a>
A 6:1 pedal ratio is fine with a MANUAL brakes setup but, if you're going to actually change the pedal ratio (not the same thing as changing the pedal height, relative to the floor), you would want to LOWER the pedal ratio to something on the order of ~4:1.
To actually reduce the pedal ratio (mechanical advantage), you would need to move the physical location of the pedal pin to a lower point on the upright portion of the brake pedal --that may present some difficulty, given the curvature of the pedal upright just below the current location of the pedal pin.
A 6:1 pedal ratio and hydroboost brakes probably means you need to install 3-point seat belts, so you won't be eating the steering wheel every time you put the brakes on, due to a high pedal ratio and a powerful hydroboost brake unit.
The input rod needs to apply in a straight line into the back of the hydroboost unit. You don't want the input rod going in at an angle. This will side-load the piston and wear the seal out.
'78 and '79 trucks actually had a revised pedal ratio, where the brake pedal pivot (fulcrum) was made lower on the pedal support. If the '78/'79 model with power brakes had a manual transmission, the clutch pivoted separately from the brake pedal --They didn't work off the same pivot like the previous models.
You may have to consider getting one of these later model pedal/pedal hangers to be able to (effectively) reduce the required pedal ratio for this adaptation.
Let me explain a little better, by moving the hydrobooster out 1-1/2 inches, the pushrod will be almost exactly where it was before. But by adding another 1/4 inch to that, that effectively lowers the pedal by 1-1/2 inches (1/4 inch times 6 (this is where the pedal ratio comes in) is 1-1/2 inches) so my pedal won't be up as high as it was. Which I feel like mine was higher than it should have been so this will correct that. When I replaced the master cylinder a few years ago it brought the pedal up about an inch and I never liked it there.
To determine pedal ratio, you would measure the overall distance between the foot pad to the fulcrum and then divide that by total distance between the pedal fulcrum to the pedal pin (where the input rod to the booster attaches)
Correctly Calculating Brake Pedal Ratio | Master Power Brakes
The smaller the MC bore diameter, the greater the output pressure you will have, for the same given amount of applied force on the brake pedal.
If the pedal ratio (as explained above and in the link) doesn't change and you have too small a bore diameter on the MC, the brakes will REALLY be overly sensitive to the application of the brake pedal.
I'm only trying to offer you some advise in the interest of helping you to avoid a destiny towards disappointment and unpleasant results.
I'm not the foremost authority on brakes but, I do have a LOT of experience with Ford brake systems .... their maintenance, installation, conversion, modification and adaptation.
I designed the adapter brackets that put these Lincoln Mk VII rear discs on the 9-inch rear end housing of this '65 Mustang that was used as the 'test mule' for devoloping this setup.
A testimonial by a guy in Texas who bought a set of these Mk VII rear disc adapter brackets from me (I was "ultrastang", in that case).
LINK: Disc Brakes
Another rear disc brake adapter bracket setup I designed, to put '94-'04 SN95 Mustang V6/GT 10.5" solid rotor rear discs on an early Mustang. (1965 fastback).
I developed another adapter bracket setup to put the 11.65" ventilated rear rotors from a '94-'04 Cobra Mustang onto a Ford 8-inch or small bearing 9-inch rear end housing.
'80 model Mercury Monarch drum brake 9-inch rear end before adapting the Cobra rear discs onto it.
After.
6061-T6 billet aluminum bracket I designed to mount a '94-'04 13" Cobra Mustang front disc brake rotor and aluminum twin piston PBR front caliper onto the '75-'80 Granada front spindles on my '68 Mustang.
Some of the different MCs and/or boosters I've installed.
'65 Mustang, '89 2.3L Fox Mustang brake booster, '99 Mustang V6 MC.
'65 Mustang, 2.3L Mustang brake booster, '95 Ford Explorer MC.
'65 Mustang, '90 5.0L Mustang GT dual diaphragm booster, Explorer MC.
'75 F350 dual diaphragm brake booster, 1.00" bore MC, '69 F100.
'65 F100 converted from single reservoir MC to a dual reservoir.
'65 Mustang, 2.3L Mustang booster, '96 Ford Windstar MC.
'68 Mustang, 5.0L Mustang dual diaphragm booster, Explorer MC.
1996 SN95 Mustang GT hydroboost unit.
...fitted up in a '68 Mustang.
'69 F100 Ranger (my truck), '75 F350 dual diaphragm booster, '95 Explorer MC, '84 F150 disc/drum brake valve.
....and the list still goes on from there.
<a href="http://s1020.photobucket.com/user/crazycracker289/media/F-100/69%20F100%20Brake%20Upgrade/IMG_0293_zpso6iwzjse.jpg.html" target="_blank"><img src="http://i1020.photobucket.com/albums/af330/crazycracker289/F-100/69%20F100%20Brake%20Upgrade/IMG_0293_zpso6iwzjse.jpg" border="0" alt="Cleaned and repainted hydrobooster photo IMG_0293_zpso6iwzjse.jpg"/></a>
LINK: Disc Brakes
After.
I don't know the exact pedal ratio of my truck and I don't really need to know it because I don't plan to change it, I use 6:1 as my guestimate because that is a very common ratio used and all I needed it for was to make a rough estimate of how much farther to move my booster out. We'll see tomorrow whether or not the pedal sits about right for what I want, I've lost my daylight for today and I am pretty much worn out now after fighting that hydro unit into place.
I would like your opinion on m/c for this truck, I have decided to go with a 1-1/8 bore unit. That's about 25% more fluid with the same amount of pedal push, but with the hyrdobooster my pedal effort will probably still be considerably less. Do you think that's a good choice?
If the pedal ratio of the setup being adapted isn't being reduced more inline with what a boosted system's pedal ratio would be (closer to the 4:1 ratio), the only other way to offset the potential sensitivity of the brakes is to go bigger with the bore diameter of the MC.
I'm very certain you don't want to be at 1.00" or lower on the MC bore. Minimum starting point would be at 1-1/6" to 1-1/8" but, you may have to go greater than this.
The smaller the MC bore, the more output pressure the MC will produce. The trade-off is a longer pedal travel and the pedal may not feel as firm.
The bigger the MC bore, the less forward travel the brake pedal will have. It will move a greater volume of fluid for a given brake pedal application but, it will have a lower output pressure.
Too large of a diameter on the MC bore size and the pedal will be very stiff and hard to depress and, it may make it very difficult to get the truck to stop within a reasonable distance.
I haven't used the style of hydroboost you have so, I don't have an actual point of reference or experience to go by in precisely what's needed.
There's just certain laws of physics and hydraulics that apply to any brake system. Finding out what the specific combination of parts is going to be is just going to be an area of experimenting and sorting out what the happy medium will be, to make it work to your satisfaction.
To start, I would say to use a MC in the 1-1/8" to 1-1/4" range. You will know from that point if the brakes are too sensitive that you'll have to go up in bore diameter on the MC. If the brakes are hard to apply, you'll have to go down in bore size.
Good luck with your conversion.
Once all the obstacles are gotten over though, the effort is usually worth it in the end.
