HELP
Old Jun 17, 2015 | 04:32 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I plan to delete, but only you can make the right decision about your truck. It is your money, time and efforts that will be put into the repair.
Old Jun 17, 2015 | 04:34 PM
F250_'s Avatar
F250_
That depends, my friend, on how much money you want to spend and whether or not you're going to keep the truck long enough for another EBPV leak to develop sometime in the upcoming 5-10 years or so.
My post above covers the options and reasons for/against each... it is your call completely. Either of the "new parts" approach will address your issue, assuming still that it is the EBPV hardware which is the leak source. The rebuild will take you longer, but is cheaper and still leaves a leak potential in future years.
Old Jun 17, 2015 | 06:18 PM
Powerstroke9292's Avatar
Powerstroke9292
HELP
there's just some pics I've captured
Old Jun 18, 2015 | 09:08 AM
F250_'s Avatar
F250_
I've attached the pictures you sent me so that others can see them too. They were too large to load individually, so I reduced the file view size and ported them all into a single PDF file which is a lot easier to work with for folks who are using their phones to respond.
From those pictures... I assume they were taken after the leak developed. Please correct me if I'm wrong.
Assuming that I'm correct above, you should check all your valve cover bolts because you might just have a couple of loose ones on the rear passenger side cover.
Anyone else have any other ideas for Brandon?
ALSO.... Brandon... any evidence of oil spraying around elsewhere in the valley, like on relays or hoses or even the under side of the hood? If so, you probably also need to check your HPOP fittings at the heads. I just read a thread where one guy had a problem with one of his HPOP fittings spraying a fine mist, and this would certainly get worse when under the higher flow associated with higher rpms.
Old Jun 20, 2015 | 08:46 AM
Powerstroke9292
HELP
it was hpop fittings guys thank you very much for your help
Old Jun 20, 2015 | 08:11 PM
F250_'s Avatar
F250_
Glad you found it.
Old Jun 21, 2015 | 02:47 AM
Powerstroke9292
HELP
scratch that it'd freaking leaking again crom the same spot ; (
Old Jun 22, 2015 | 08:40 AM
F250_'s Avatar
F250_
If it is still leaking from the same fitting, what was it that you did for the solution? Tighten only? Rebuilt the fitting with new internal oring? Try to just seal the threads into the head? Replace the fitting altogether?
Old Jul 8, 2015 | 08:55 PM
Powerstroke9292
HELP
Trucks fixed it was the pedistal seals now just gotta tend to the boost boots that keeps popping off ugh
Old Jul 9, 2015 | 08:58 AM
F250_'s Avatar
F250_
Great. Thanks for the feedback on the solution. Those pedestal o-rings can be a pain. What I try to remember to do with o-rings is to use a thin film of tacky grease to help them stick and stay in place while I'm putting things back together (but I do NOT always remember because I just don't have to do it very often). I just learned to apply the same trick to my u-joint grease cups a couple of weekends ago. Works great.
Old Jul 10, 2015 | 02:42 AM
Jdeshler's Avatar
Jdeshler
I have pinpointed two of my 7.3 leaks with the video recorder on my phone.. It gets way past the line of sight..
Be patient, you'll find it..
Old Jul 10, 2015 | 08:30 AM
F250_'s Avatar
F250_
No video attached.
BTW... where in LA are you located? I'm orignally from Satsuma (north of Mobile on 43), and still have family there. Been in Birmingham for almost 9 years now, and I travel to Selma regularly for day-long business trips.
Old Jul 17, 2015 | 12:42 PM
  #28
Powerstroke9292
HELP
Ran into a case of bad fuel lol
Old Jul 17, 2015 | 12:43 PM
  #29
Powerstroke9292
HELP
What kind of fuel additives are you guys running
rob_96
Feb 10, 2025 06:38 PM
B-Rad88
Mar 5, 2018 09:52 AM
alexk3303
Oct 26, 2015 10:50 PM
85sp600
Nov 4, 2010 07:09 PM
surveyguy
70
May 25, 2009 04:16 PM
