oil leak
Old Nov 4, 2010 | 06:01 PM
85sp600's Avatar
85sp600
oil leak
hey all. got a prob 2001 f250 psd w/13000 miles got truck in tn for a steel and when got there to pick up seller showed me bill from ford for replacing wire harness and other stuff bottom line is it was sitting for a while and mice got into eng bay,,, 10,000 miles later i find a mouse house under turbo and valley area, put a nother new starter on cause last one was not catching in cold mornins starts,and found oil all over starter
so i brake clean valley and blew it out with air everything had oil on it any help would be great
thanks
Old Nov 4, 2010 | 07:09 PM
woodnthings's Avatar
woodnthings
The most common oil leak in the valley is from the HPOP hoses/fittings or the turbo pedestal. The EBPV can also be leaking. Now that you have cleaned it, you should be able to find it a little quicker.
You may also look at the valve cover on that side, could be loose and leaking, or the seals on the gasket are worn and leaking.
