Stumped: Low Boost
Old Jun 14, 2015 | 08:25 AM
exbxtoy's Avatar
exbxtoy
Originally Posted by Tugly
I left my red line capped until I could exceed 35 PSI boost - then I hooked it back up to protect the intake valves. We wouldn't want those opening precipitously, now would we.
I have seen 20 PSI boost on a stock truck, red line capped, and an AIS with no other mods. Same truck, bumped the exhaust to 4" and I topped off at 22 PSI boost - at which point the truck would defuel. 22 PSI is max without a chip or a boost fooler - the type that regulates the pressure to the MAP line.
The adjustment for the wastegate is a turnbuckle on top. The hardest part of the whole job is to not lose the C-clip keeper. I parked a Mythbusters uber-magnet on top of the turbo while adjusting the wastegate, in case I dropped the keeper.
I see, than I plan to leave the red line capped until I reach 35 PSI. I also have the RiffRaff boost fooler and 4 inch exhaust. It does not appear possible to adjust the wastegate while on the truck, is it?
Old Jun 14, 2015 | 08:48 AM
TheBigBee's Avatar
TheBigBee
Stumped: Low Boost
You can you but like tuglu said be careful not to lose the c clip.
Old Jun 14, 2015 | 09:54 AM
Tugly's Avatar
Tugly
Yeah... those instructions were how I did it with the turbo in the truck. It would have been easier to do this while the turbo was out - just like the instructions said to do (which I read after the install and I had low boost).
Old Jun 14, 2015 | 12:42 PM
JOHN2001's Avatar
JOHN2001
Tie a piece of dental floss/fishing line around the C- clip and the other end to something that is not going anywhere like a bolt. This way when it does go flying around all you have to do is pull it back up from its hiding spot.
Old Jun 15, 2015 | 06:21 AM
danskool's Avatar
danskool
Go Bills !
My un-chipped truck as well as dads, would only hit 14/15 psi boost. All new boots and no leaks. both of them. Untill I chipped my truck it would then go higher.
Old Jun 15, 2015 | 06:56 AM
Tugly's Avatar
Tugly
About 17 is the norm on a Superduty. Without saying you are mistaken, I have seen people swear on a stack of bibles that they have no leaks, then finally find one or more. It's always possible something else is at play, like a loss in turbo efficiency or wastegate control needs some attention.
Old Jun 15, 2015 | 04:44 PM
danskool's Avatar
danskool
Go Bills !
True. And to add the gauge itself,barometric pressure, sea level , humidity. The moon is aligned. We have gauges at work that fail calibration. It is frustrating that we buy new gauges to only return them because they fail . being 15 psi in an un chipped truck . I would call it good and remember that is the norm for trouble shooting purposes and the reading on that particular gauge . Everyone said I should get 17. I chased after it for two freakin years. New plenums . Boots . Clamps. Gaskets. A couple of different gauges. The turbo on the garage table a couple times. I gave up. Even put in two different sets of blades . Over 2 psi. Ha. I figured what the hell, that is beer money I am spending and wouldn't notice the difference towing anyways. Grew tired of messing with it . Tossed in a dp tuner and it is a different now ! Hal la!
Just saying I hope the op is not spending the money I did tracking down 2 or 3 psi as I did to only loose out. For what reason I asked my self. More important to only know what it is and it stays there .
Old Jun 16, 2015 | 07:57 AM
Tugly's Avatar
Tugly
With the other low boost (13-14 PSI) thread that's active now, everything being done is testing - not spending. Now that we have some test results, there are indications that spending can make an improvement with boost. In this thread, we're talking a GTP38R giving low boost - which is a clear and obvious problem. While the GTP38 is a nice turbo, I always see a big efficiency loss (growing gap between EBP and MAP) when the boost numbers climb beyond stock boost. The 38R gives me very close to 1:1 all the way up the dial (I limit mine to 35 PSI), but I have "balanced" my entire air in/out system.
Old Jun 16, 2015 | 08:31 AM
exbxtoy's Avatar
exbxtoy
I spoke to Clay yesterday about this, and he said my numbers made sense to him (14PSI Max), because without running a tune, the GTP38R needs more fueling behind it to produce more boost. Before I jump on the tune wagon, and I have looked into DP Tuner, and really like what they have, and also looked into the Hydra tunes, what else should I test to make sure my engine is 100%?
Old Jun 16, 2015 | 08:35 AM
timmyboy76's Avatar
timmyboy76
spitballing here..but a compression test would direct my "sight-glass' on a buckzooka....more common would be...intake/exhaust leaks, sensors are "true"...etc
Old Jun 16, 2015 | 09:34 AM
Tugly's Avatar
Tugly
Yes, a compression test would preclude more money going into an engine.
As mentioned, my 38R is about 1:1, the MAP should closely parallel the EBP. A failed wastegate adjustment will kill the EBP (and subsequently the MAP/boost), and no amount of tuning will undo that. At the time I had my 38R faux pas, I had Stage II injectors with all the air mods and tuning - but couldn't build EBP or boost above 18 PSI. Total and utter fail. Tighten the wastegate arm and up comes 35 PSI boost with 36 PSI EBP.
jump05powerstroke
6.7L Power Stroke Diesel
Apr 22, 2017 11:56 PM
MHammer21
Jul 1, 2011 07:32 AM
c00nhunterjoe
Jul 13, 2007 11:56 PM
crapr6
31
Oct 17, 2005 03:37 PM
Craze
Aug 23, 2005 12:27 PM
