Best Steering Gear Replacement
Really seemed nice.
So to the question about bad cores. They don't try to repair them.
Also they don't have a source for the major hard parts. I was told
that one of the effects of turning the mesh-load adjust is extra wear
on the gear teeth to the point that they can break off. Also it seems that
there are some people out there that like to play with the adjustment on a
fresh box for one reason or the other. They pre set them and then do a pressure
test on the bench to make sure that the box does not leak and it works.
That is not saying that one won't leak once installed do to loads that they
can't reproduce easily on the test bench (my wording) The load being
large tires and things like that.
Anyway back to the work at hand. They get a box in and have a look before
they issue the core. If it passes then you get the core fee back in not then
they will be talking to you about what and why.
They clean and then do some servicing on the unit then hand assemble it.
Not like some place in China that just tosses it together and hopes.
It gets all new seals and the ***** are sized to the unit. I think he said
3 sizes of ***** to pick from to make it work correctly.
Also if you want to have it painted they can do that for you.
When it comes to group buys they do some planning so that they are
not short on stock and in a rush.
Also if you happen to be out in the middle of nowhere they can ship
with faster services than the normal Pony Express.
Last thing I did invite then to come on and say hi and do there own Q&A.
So looks like I'll be picking up a box sometime this summer.
Sean
Really seemed nice.
Sean
Kevin
I forgot to ask about why the short warranty but did ask why it gets
denied some times. They said that for one reason or the other people take
"New" out of the box gear sets and readjust the mesh load. They put a
witness mark on it. If that shows the gear has been opened then your
warranty would be void.
On Customer service. When you take into account the fact that they were
busy and were able to take time to chat and show me a gear box explain
what is done I got a good feeling about the service.The guy I talked with
did say that there are some people that no matter what you do they are never
are happy how you fix a problem.
But from my time there I got a good feeling about the customer service.
I have been to places where things felt wrong and this was not one of them.
Sean
The reason the Ford Motorcraft boxes are more expensive then the aftermarket retail options is they replace the sector shafts with new ones, something the rebuilders cannot get. You don't have to take my word, it's posted in Ford's parts documentation and it's also shown if you click on the info button for the item on RockAuto's site.
I don't git why Redhead does not place the used at-rish parts in a MagnaFlux machine.
It's not that hard to do and reasonably easy to read.
BTW Do you happen to know if the original Ford or the replacement parts are cast or forged?
Sean
6.0L Tech Folder
https://www.ford-trucks.com/forums/1...group-buy.html
Here's the pc of crap...
