Best Steering Gear Replacement
Old Jun 19, 2015 | 08:53 AM
dannyboy950's Avatar
dannyboy950
I think ToomanyToys hit the nail right on the head. Their is a adlustment screw on each gear box for Minimal adjustment once you go beyond that you have to get a replacement part. I have noticed over the last few years I worked that replacement parts no longer lasted as long as they used to.
Old Jun 19, 2015 | 05:49 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
Getting a rebuilt from a core that has 50k miles on it is much different then a rebuilt core with 150k if the worm and sector is not replaceable.
Redhead can not get new gears, I had that question.
Old Jun 19, 2015 | 05:51 PM
Grant-Dieseltech
Originally Posted by Yahiko
Well sense they are local to me I might just stop in and have
a chat with the Big Boss. I have also been reading the bad reviews
and have not gotten around to replacing mine because of that.
Who knows might be fun or I might get tossed out on my ***.
Sean
Post back because I want to know. I have installed many of them without issue. Just ordered one yesterday for my truck so we will see.
Old Jun 19, 2015 | 07:46 PM
Yahiko's Avatar
Yahiko
Growing up here they have always been the go to place
for steering box replacement.
This next week is going to be a little full but I will see if I
can get in to see them on Wednesday.
Sean
EDIT : They are not in seattle. There address is 4302 B ST NW AUBURN, WA 98001
I go right by that every two weeks when I go up to Kent to visit. I think I will be stopping in on Monday.
Old Jun 19, 2015 | 07:48 PM
KDAVID1's Avatar
KDAVID1
I bet Triump group could get em (aviation company) or Hispano (in France)
Old Jun 19, 2015 | 08:19 PM
TooManyToys.'s Avatar
TooManyToys.
So without replacement W & S all the rebuild industry can do is determine how much wear is acceptable and reuse those parts along with new shaft bearings. As the model year gets older and develops higher wear, choices will need to be made. And unfortunately the common internet instructions for just tightening the top adjustment screw without measuring the interference with a torque value on the worm shaft just wears out boxes more then they should, so less good cores will be out there.
KDavid1, while a machine shop can usually make anything, reverse engineering these parts and the machining required may not be economical. (Images just an example)
Old Jun 19, 2015 | 08:26 PM
Grant-Dieseltech
Cardone makes an all new unit. I think it runs about $515 for the 05 to 07 if i remember right. The problem there is the lack of quality from so many of that companys parts. The tolerance they use making a brand new gear could be worse than the core redhead thows away for all we know.
Old Jun 19, 2015 | 08:29 PM
KDAVID1's Avatar
KDAVID1
True--the companies I mentioned are gear box companies for turbine engines-so they have the means for sure although probably not enough business to justify.
Old Jun 19, 2015 | 08:31 PM
Grant-Dieseltech
To be honest i didn't know a turbine had a gearbox.
Old Jun 19, 2015 | 08:34 PM
Yahiko's Avatar
Yahiko
Yep they do. If they did not then the things like pumps
and generators would be spinning 100,000 RPM give or
take some. Just a tad too fast for things like that to spin.
I don't know if this link will work to play here or not but
they show the base engine without a gearbox. You can
see how it is all one shaft front to rear and in the image above
you can see the accessory drive that is part of the gear box.
https://player.vimeo.com/video/44470...=0&autoplay=1;
Sean
Old Jun 19, 2015 | 10:07 PM
KDAVID1's Avatar
KDAVID1
Good pic. Copters have two depending--the one I'm dealing with now has two. A reduction gear box and accessory drive gear box. They are pretty simple but I understand the shimming is a pain. Garrett (used to be garrett) it's now honeywell made a good one for turbo props. Has a big gearbox on it--thing is LOUD. Rolls Royce prop engines has a big one as well ( C130 engines and some others)
Old Jun 20, 2015 | 02:55 AM
Yahiko's Avatar
Yahiko
My self I like the little A250
that comes in the 206 Bell Jet Ranger.
Bell 206
Aircraft family
The Bell 206 is a family of two-bladed, single- or twin-engined helicopters, manufactured by Bell Helicopter at its Mirabel, Quebec plant. Wikipedia
Range: 436 miles (702 km)
Wingspan: 33' (10 m)
Length: 40' (12 m)
Cruise speed: 136 mph (219 km/h)
Top speed: 138 mph (222 km/h)
Unit cost: 900,000–1,200,000 USD
Engine type: Allison Model 250
Also found in the Bell OH-58 Kiowa I like that little bird.
Sean
Old Jun 20, 2015 | 09:37 AM
  #28
KDAVID1's Avatar
KDAVID1
It's actually a RR250 now Rolls Royce kept them going after they bought Allison. The RR300 and 500 are almost the same design. Now the bad boy they make (in partnership with Honeywell ) is the CTS800. That puppy is the Ferrari of light to medium duty engines. Too bad the US dropped the Comanche program.
2006 F350 4X4
Old Jun 20, 2015 | 10:04 AM
  #29
69cj's Avatar
69cj
WOW, from gearboxes to Hellos
Old Jun 20, 2015 | 11:23 AM
  #30
KDAVID1's Avatar
KDAVID1
Sorry for the
