Having a hard time.
Old Jun 12, 2015 | 06:28 AM
truckrider814's Avatar
truckrider814
Having a hard time.
Ok i've searched and searched an maybe im not looking hard enough but i can't seem to find the right part numbers for all the seals an bearings i need when i do my ball joints on my 06 i keep finding numbers for the years that have leaf springs. Can yall help me out here?
Old Jun 12, 2015 | 06:41 AM
David7.3's Avatar
David7.3
Motorcraft - AC3Z1104F
Timken SP940200 Replaces ford 6C3Z1104BA, 7C3Z1104B, AC3Z1104F, I like the Timken, there the tapered roller bearing, more expensive but will last a long time, plus it comes with a new ABS sensor and wire and the 4 studs that hold it in, so you dont have to swap that over.
Old Jun 12, 2015 | 10:36 AM
truckrider814
I don't wanna replace the whole hub im just gonna be going in to replace the ball joints and need the seals inside the hub.
Old Jun 12, 2015 | 03:18 PM
mhoefer's Avatar
mhoefer
You need the innder o ring and the outer felt, depends on the year of your hubs. The felts come in pairs, one for test fit, one for final fit, I ussually keep the second for a backup if I need to take apart the autohub for lubrication. Ford always stocks them, so do most the major autoparts like NAPA. Bout $30 a set for me in Canada.
Old Jun 13, 2015 | 04:27 PM
truckrider814
Well I guess I don't need nothing right now. I jacked it up an check everything an nothing moving so my clunk when I turn left ain't the ball joint.
motochris
Feb 29, 2016 11:55 AM
brettdacosta
16
Sep 26, 2013 04:53 PM
HAWG06
Apr 21, 2012 08:36 PM
meier63
Aug 18, 2011 10:00 AM
tws1616
16
Apr 12, 2010 04:25 PM
