94 7.3 E4od Shifting problems
Old Jun 8, 2015 | 04:45 PM
Coz2122's Avatar
Coz2122
Auto 94 7.3 idi turbo.. Replaced tach Sensor. New tcm. New trans harness... Trucks working and shifting fine... Make a right turn and the trucks rpm shoots down to zero and won't shift... Hmmm... Checked tach connection and it was good. Also read around 3.03k on the meter... Looked under the dash and the same color wires for the tach are disconnected and touching bare metal... Did I short out the cluster?? Thoughts cause I'm lost?? Thanks guys
E4od trans
Old Jun 8, 2015 | 08:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
never heard of this one.so what happened after you repaired the wires? or haven't yet? if not,id start there.
Old Jun 8, 2015 | 08:29 PM
Coz2122's Avatar
Coz2122
Re connected the wires and still no change. I can shift manually through the gears 1,2 and D but it won't go into fourth. I don't know where to go from here.. That's why I'm wondering if it fried the gauge cluster when it was exposed?? Just a thought. How can I diagnose that??
Old Jun 8, 2015 | 08:41 PM
FORDF250HDXLT
you connected the wires,insured they can't chafe again but the tach is still inop correct?
if so,it probably blew the fuse.check that now that they've been repaired.
Old Jun 8, 2015 | 08:43 PM
Coz2122's Avatar
Coz2122
Checked that (#17) and it's still good. I'm seriously stumped at this point...
Old Jun 8, 2015 | 08:52 PM
FORDF250HDXLT
what about P in under hood fuse panel? I and U need to be good or tach doesn't work either but od light should be on i think if those blow due to the teca relay not getting power when they blow but check 'em.
Old Jun 8, 2015 | 08:59 PM
Coz2122's Avatar
Coz2122
I'm not sure where those are located =\
Old Jun 8, 2015 | 09:04 PM
Coz2122's Avatar
Coz2122
Ok I'll send to my mechanic since he's looking at it tomorrow. I hope it's something that simple...
Coz2122's Avatar
Coz2122
And sorry I didn't see your diagram when you first posted.
broncrider051990
Jul 9, 2013 02:21 PM
Brant Bowrifle
Aug 12, 2012 12:20 AM
mirage5058
Mar 30, 2011 12:04 AM
1bigjoe
Jan 26, 2010 09:08 PM
94_IDI
Sep 9, 2008 11:23 PM
