no tach
Old Jan 26, 2010 | 03:09 PM
1bigjoe's Avatar
1bigjoe
no tach
1990 7.3 -e4od, no tach, checked fuse in the #18 position 15 amp is good
changed the sensor on the gear cover, cleaned off the sensor at the differencial, cleaned off the connection on the side of the trans. now the only thing i can think of is maybe the tach in the cluster is just not working i'm i missing somthing?
Old Jan 26, 2010 | 04:44 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Could be a bad ground.
If your tach doesn't work, your E4OD must not shift smoothlly all the time?
Old Jan 26, 2010 | 09:08 PM
1bigjoe's Avatar
1bigjoe
it doesn't shift right, what is grounded that i should check?
ALedbetter1
Jun 26, 2013 05:14 PM
brobrad
1997 - 2003 F150
Jan 15, 2013 04:10 PM
Iowa-Rob
18
Nov 18, 2012 09:09 PM
ihf-350
Dec 30, 2011 05:50 PM
