TPMS Warning Light
Old Jun 8, 2015 | 09:45 AM
Leonandlisa's Avatar
Leonandlisa
TPMS Warning Light
for the last couple months when not towing I take the front tires to 65 psi and the rears to 50 psi. It gives me the warning light which I click OK to every time I start it. This weekend I put everything back to 80 psi getting ready to tow and I can't get the warning light to go out anymore. I double checked my pressure to make sure everything was OK and it was.
I will be taking it in unless someone knows a reset or something else to check out before I do.
Thanks
Leon
Old Jun 8, 2015 | 01:52 PM
FordService's Avatar
FordService
Official Ford Rep
Thanks
Leon
Hi Leon,
Taking your truck in to the dealer is a great next step. How many miles are on it currently? I'll start investigating some ways to help out.
Crystal
Old Jun 8, 2015 | 05:00 PM
Leonandlisa
Originally Posted by FordService
Hi Leon,
Crystal
Almost 23,000 miles on it right now, I will get it scheduled for a visit.
Thanks
Old Jun 8, 2015 | 05:40 PM
Ricohman's Avatar
Ricohman
Thanks
I would reset it.
You know you can reset it to whatever pressures you want, front and rear.
Just Strokin's Avatar
Just Strokin
When you say you put the pressures back to 80psi...was this all tires or just the rear?....on the SRW, fronts are 65 psi and the rears are 80 psi.
Old Jun 9, 2015 | 08:08 AM
Leonandlisa
I set up an appointment for the dealer this morning and when I started up the truck the light is off, so not sure why it was on all weekend and not today. I will reschedule when or if it comes back on.
To clarify on the pressures it is 65 psi in the front and 80 psi in the back, I did write the wrong before.
Old Jun 9, 2015 | 08:50 AM
FordService
Official Ford Rep
I set up an appointment for the dealer this morning and when I started up the truck the light is off, so not sure why it was on all weekend and not today. I will reschedule when or if it comes back on...
Sounds good, Leon. Keep us in the loop.
Crystal
Old Jun 9, 2015 | 07:11 PM
System's Avatar
System
Prolocutor
Leon, just so you know, your dealer can reset your rear threshold trigger to anything you like. I do the same as you and also lower my rears to 65 in the off season when I'm not pulling my 5th wheel. So, I had my dealer program my rear trigger to the same as the front and now I can lower my rear pressure with no TPMS alert. It also allows tire rotation without reprogramming tire location. Some dealers don't want to do it as they are afraid of liability if you forget to air back up to 80 before towing heavy. My service dept. told me it was impossible. So, I went to the owner who I just dealt with when buying the truck and asked him if I need to get it serviced elsewhere from then on. (Perhaps I'd buy my next truck there too?) The service writer who told me it was "impossible" suddenly had it done for me in ten minutes.
Old Jun 9, 2015 | 11:01 PM
Leonandlisa
Thanks for that information, I will talk to the dealer and see if they can do that. I'm sure they can, they have been easy to deal with every time I needed something.
Leon
paddler65
Sep 21, 2021 01:35 PM
NFAFAN
May 3, 2018 01:47 PM
Demo-man
6.7L Power Stroke Diesel
Feb 7, 2014 04:48 PM
whiteywhip
17
Jan 17, 2013 09:50 AM
Sportsman
Jan 10, 2011 02:54 PM
