TPMS warning issue
Old May 2, 2018 | 12:17 PM
NFAFAN's Avatar
NFAFAN
TPMS warning issue
I just bought my F350 SRW 6.7 Lariat, I aired down the tires to 60lbs and now every do I get a warning and the TPMS warning light stays on. 20inch mich. 4x4
Thanks guys. BTW Yes I searched and didn't find much of anything that pinpointed this issue. Perhaps my Google foo is weak LOL
Old May 2, 2018 | 12:50 PM
BK39's Avatar
BK39
What's your question again?
Air up to 65 psi, drive around a min, to get the light to go off and stay off.
Old May 2, 2018 | 12:55 PM
Kreep's Avatar
Kreep
Or get FORScan and set the truck for lower warning pressure. I assume you are savvy enough to know that you should bump the pressure back up when you put the truck to work...
Old May 2, 2018 | 01:00 PM
briangp's Avatar
briangp
Just a friendly reminder too, the tire pressure won't update until you start driving.
Old May 2, 2018 | 01:02 PM
Buliwyf's Avatar
Buliwyf
Anyone remember the code to turn the TPMS off with FORSCAN?
I don't want to bother with sensors on my other set of wheels.
Old May 3, 2018 | 11:36 AM
Truckie256's Avatar
Truckie256
My 17 250 pressure will reset at a standstill still.. just turn off truck afor a minute and restart... Also on my 2012.. lift and 37" BFG AT tires. It was50 psi... I cut a black vinyl cling circle and stuck it to cluster glass to cover light... Dealer saw this at service and reset to lower pressure... I have seen tpms tool online for $100... If u do this alot....
Old May 3, 2018 | 11:37 AM
Truckie256's Avatar
Truckie256
FYI..some dealers won't reset tpms parameters ..affraid of liabilty
Old May 3, 2018 | 11:40 AM
NFAFAN's Avatar
NFAFAN
it would appear the front wheels are set for some number below 60lbs and rear wheels are set for 65lbs.
Not hauling anything soon just adjust for comfort. Heat here in AZ plays a huge roll in TP. We can go from 60 in the AM to 100+ easily by afternoon.
Old May 3, 2018 | 01:46 PM
Spatzboy's Avatar
Spatzboy
I have my pressures at 58 and no sensor issue. Much better ride.
Old May 3, 2018 | 01:47 PM
psdxohio's Avatar
psdxohio
What can you do with this $100 tool? From the context of your comment it sounds like you could adjust the expected tire pressure to suppress TPMS alerts for lower pressures. But I thought that would be exclusively a Forscan thing?
Sparky570
Dec 11, 2017 10:08 AM
fmuguira
Oct 1, 2017 03:49 PM
bushpilot
May 10, 2017 10:06 AM
whiteywhip
6.7L Power Stroke Diesel
17
Jan 17, 2013 09:50 AM
