Sponsored by: Real Truck
Mirror Adapters
Old Jun 1, 2015 | 10:26 AM
ligito's Avatar
ligito
Mirror Adapters
I have a '99 SD and bought the mirrors for 2008
1999 Ford F250 Super Duty Truck Power Heated Signal & Clearance Light Towing Telescoping Upgrade Mirror Pair at 1A Auto.com
Is this the correct part to start with, to add the turn signal and heat?
1999 Ford F250 Super Duty Truck Power Heated Mirror Wiring Adapter Pair at 1A Auto.com
I know that I will have to find a source circuit for the signal and lights but need to know the correct adapter.
Old Jun 1, 2015 | 05:40 PM
SGorman13's Avatar
SGorman13
99 SD do not have the wiring harness for heat or signals built in so the adapter you are buying will only work for the adjustment of the mirror itself. You will have to wire the heat directly to a switch or a wire that is constantly on. For the turn signals you will have to wire it directly to your wiring harness for your turn signals.
Old Jun 1, 2015 | 08:00 PM
ligito's Avatar
ligito
That is why I mentioned finding a source circuit. I intend to wire the inside cab stuff, myself.
I just need to find the other half of the connector, for the inside cab portion, if the adapters in the link are correct.
Old Jun 1, 2015 | 08:16 PM
ligito's Avatar
ligito
1. Where can I get the mating connector for this?
2. And will the adapter that I showed in my original post and the mating shell that
I need, allow me to then connect to my additional wiring in the cab?
ligito
Aug 2, 2016 04:40 PM
FROG147
Aftermarket Products
Jul 29, 2012 08:04 AM
KJNDIVER
Oct 9, 2011 10:07 PM
sic inside
Mar 20, 2005 09:56 AM
mmcarter
Oct 28, 2002 04:10 PM
