Auto to manual flexplate
05-28-2015, 05:53 PM
on
Im swapping a m5od into my 94 ranger 4.0 2wd the only part i dont have is the flexplate between the engine to trans do i need it from the manual truck?
05-28-2015, 08:59 PM
A flywheel a clutch disk and a clutch pressure plate. And a clutch master cylinder.and the pedals from a standard shift ranger.
05-28-2015, 09:16 PM
on
I have all that. So i dont need a flexplate/dust sheild from donor?
05-28-2015, 09:24 PM
You need the metal plate that goes between the flywheel and engine block. The flywheel has the starter ring gear on it.
05-28-2015, 09:29 PM
The flywheel replaces the flexplate. You can't physically bolt both a flexplate and flywheel to the end of the crankshaft.
05-29-2015, 06:06 AM
on
That metal plate is what i need and meant thanks
05-29-2015, 06:52 PM
Metal plate (engine block plate) from a manual, not the auto.
Dave
05-30-2015, 07:53 PM
on
That sucks anyway to make the auto plate work?
pvfd1220
1983 - 2012 Ranger & B-Series
06-19-2018 03:42 PM
Joel Cassell
WTB - Parts & other
08-23-2016 03:35 PM
73 ford guy
05-20-2014 06:43 PM
67F250RET
13
09-17-2012 07:25 PM
Dogsnatcher420
07-22-2011 08:45 PM
