Aerostar Ford Aerostar
Sliding Door Question
Old May 28, 2015 | 10:27 AM
ftv37's Avatar
ftv37
I have a 1994 Aerostar and the door is jammed can I take it off to inspect it.
Old May 29, 2015 | 07:42 AM
DFord's Avatar
DFord
I can't tell you how to get the latch to release but these pictures show what is causing the door to jam. I had an awful time getting the door to release so I could get at the problem. The door jams because it isn't pulled into its proper position while you're trying to close it.
Hope these pictures help.
This picture shows the leading edge of the sliding door center support and you can see it starting to crack.
When it breaks completely the door will jam as you try to close it.
This picture shows the fix I did to hold the sliding door center support in place after it broke completely in two.
Old Jun 1, 2015 | 08:15 AM
Jose A.'s Avatar
Jose A.
the problem can also be the Latch assembly mechanism that got stuck in the locked position.
you might try kicking the door from the inside at the rear pivot point, (not at the front of the sliding door where the pull-handle is located, but at the rear where the latch is).
Old Jun 2, 2015 | 05:29 PM
ftv37's Avatar
ftv37
After some gentle adjustments with a size 10 wrench got the door open.Made adjustments to the striker and the door to compensate for sag,sprayed lube in lock assembly and all is well.Thanks to all
Old Jun 6, 2015 | 12:28 AM
xlt4wd90's Avatar
xlt4wd90
One problem I encountered was with the latch mechanism sticking. I had to take the panel off to lube it:
https://plus.google.com/photos/11555...67774490549511
DisneysPatB
Nov 22, 2017 06:43 AM
ericthor
22
Oct 13, 2016 04:54 PM
1998F250SC
1997 - 2003 F150
Oct 25, 2009 10:50 AM
Joker50
May 28, 2008 03:29 PM
neilc88
Aug 9, 2006 01:06 PM
