Inside Door Handle
Old Nov 20, 2017 | 05:49 PM
DisneysPatB's Avatar
DisneysPatB
Inside Door Handle
What is the secret to the interior door handle rod hitting the door handle release to open the door. I have installed new handles that are shiny and unpitted and there is an issue with them opening the door. PO had added a piece of thick wire looped to extend and prevent this. Why is this an issue???
1970 F250 CS
Old Nov 20, 2017 | 06:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Upper pic, caption should read 1968/72, because only the 1967's are unique.
Old Nov 21, 2017 | 07:16 AM
TeachNlive4ever's Avatar
TeachNlive4ever
They can be a bear. The tang or lever that extrudes from the door handle goes under the door opener. Almost every time I mess with them I have to keep messing with them. There should be a plate that goes on the door, them the metal door panel and then the door handle/opener. I think at one point I loosened the nuts and giggled it about and it kind of seemed to fall into place. I did the same on the other door and had good results. I don’t know what it was, maybe the door gods were smiling on me.
Old Nov 21, 2017 | 09:50 AM
DisneysPatB
OK TeachNlive4ever, that is the answer I was looking for. Thanks. I guess the only mistake I made, I jiggled the handle instead of giggling it. Not sure how much of a difference it makes, but I do not have the plate on either side.
Seems this is not included on LMC's site. Will have to check others.
Old Nov 21, 2017 | 10:02 AM
TeachNlive4ever
219A59 is almost like spacer or shim. Maybe try some washers?
Giggle is a VERY important step as it aids in the prevention of flying tools. I guess you could try jiggling....
Old Nov 21, 2017 | 10:06 AM
TeachNlive4ever
Not all 68-72 had the 22634, the deco plastic chingadera. I know you’ve never heard this before, but it could be going too deep.
Old Nov 21, 2017 | 11:16 AM
DisneysPatB
Too funny.
Old Nov 21, 2017 | 05:28 PM
lilorbie's Avatar
lilorbie
TeachNlive4ever man it,s been more years than i care remember since i have heard the term chingadera.
Old Nov 22, 2017 | 01:11 AM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
I goofed in the other direction. Adding sound-proofing, I made it too thick, and had a devil of a time getting it thin enough to open the door. Made for at least one creeped-out date situation! If it was pulled too hard, it would click-over the correct point, and stick in the 'pulled' position. Then the door had to be opened from the outside. (No reference there to the date situation...)
Old Nov 22, 2017 | 06:43 AM
TeachNlive4ever
Hmmm, thanks 72-34ton. With the cold weather coming in, I may have to work on my doors so she can’t escape....
We put our sound deadner on the door skin and 6 mil plastic taped to the inner door panel. I’ll have to change that for a little “Brown Chicken Brown Cow”. ( I crack me up)
Pebcak
18
Sep 29, 2016 01:03 PM
alconk
Jan 26, 2010 05:46 PM
Joker50
May 28, 2008 03:29 PM
twise
Aug 6, 2007 12:51 PM
