6.0 thumping noise
May 28, 2015 | 07:34 AM
6.0 thumping noise
I have an 06 f250 superduty, 6.0 . Last week I rolled into the the throttle up to about 95 and then backed off. After which it developed a thumping noise, not metal, more like an air thump in the intake. Not throwing any codes, still runs strong, pulls boost, etc. The motor does have 285,000. Any ideas.
Thanks
May 28, 2015 | 07:42 AM
Did you let off the throttle all at once. Have you ever had turbo fart
May 28, 2015 | 07:46 AM
Yes, I let off the gas abbruptly, not sure on the turbo fart.
May 28, 2015 | 08:10 AM
Turbo fart. Turbo going to need to be cleaned.
May 28, 2015 | 09:14 AM
I took it to local mechanic, he hooked it up to the scanner, disconnected the turbo, noise was still there.?
May 30, 2015 | 02:34 PM
Quote:
Originally Posted by
9228.bobcat
I don't know anyone who cleans their turbo after every time the turbo suddenly closes and pushes air back. Even brand new you can make this happen.
If you can't get this to recreate at any other circumstance other than getting high boost and then letting off the pedal abruptly, it is a turbo fart, nothing to be worried about.
May 30, 2015 | 03:57 PM
Is it thumping out of the intake even sitting there at idle?
Or does it only make that fluff, fluff, fluff or thump, thump sound after getting on it hard and then backing off quickly?
Better yet, does it sound like this? If it does then it's normal because there's no blow off valve on these.
May 30, 2015 | 10:40 PM
shultzaberger
6.0L Powerstroke SCT Tuned "Turbo Fart" - YouTube
I just played this video, from across the room my wife says "That sounds like the turbo thing farting"
Josh Toomey
Apr 17, 2017 08:01 PM
Jd1a
Jun 14, 2015 04:38 PM
cjfarm11
Jun 16, 2010 08:24 AM
OK RANCHER
Jun 12, 2009 02:46 PM
SonicBlueF350
Oct 20, 2006 01:16 PM
