Smoke and knocking
Old May 13, 2015 | 10:03 PM
Anthharv's Avatar
Anthharv
Smoke and knocking
Hey I let a buddy barrow my truck and it's now 1,500 miles away on the side of the road.White smoke, knocking and lost power. Truck has 133,000 reman engine installed at 46,000. Is it common for hydro locking to bend a rod? He sent a video and it def sounds like a rod and degas is empty. Thanks guys
Old May 13, 2015 | 11:23 PM
04badford's Avatar
04badford
Don't Try to Start the truck , yes it will bend a rod. did the EGR cooler let go? how hot did he get the Engine ?
Old May 14, 2015 | 12:22 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Where about a is he?
Old May 14, 2015 | 06:15 AM
Anthharv's Avatar
Anthharv
He said never got hot. Just lost power and it shut down blowing smoke. The video he sent me sounds like a rod. Waiting on a semi to bring it back to Indy.
Old May 14, 2015 | 06:16 AM
Anthharv's Avatar
Anthharv
Just north of Dallas.
Old May 14, 2015 | 07:20 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I was hoping a little closer to Tulsa... On the surface it sounds like it's trying to hydrolock, and that can bend rods but you may be ok if you can clear the cylinders. You will want to pull the glow plugs and crank it to clear it/them out.
That will also help you determine whether its fuel or coolant and which cylinder.
Post back with the results. Good luck.
Old May 14, 2015 | 07:33 AM
Anthharv's Avatar
Anthharv
Thanks man
Old May 14, 2015 | 06:44 PM
04badford's Avatar
04badford
DONT GET your FACE down by there( alitte bit of pressure ).
Old May 31, 2015 | 09:08 AM
Anthharv's Avatar
Anthharv
UPDATE..i finally got my truck back from TX....only took 3 weeks to get it shipped up here! The guy i let barrow it said the degas bottle was empty so i thought it was hydro-locked with coolant...not the case. It wouldn't turn over, so i pulled the glow plugs out. I kept bumping starter after ever glow plug it pulled. Finally cylinder 8 let the engine turn over and fuel came out. My question is do i go buy an injector for it and risk it still having a bent rod or just go a engine coming for it. The video my friend sent me of running and smoking it sounded like a rod was gonna come out and any time. I pulled the injector and the orings were screwed up on it. just wondering if anyone has had a rod bent with a flooded cylinder.
Old May 31, 2015 | 09:26 AM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I can't answer your question, but I know it can bend them. I would make sure the cylinder is clear, and replace the injector with an OEM reman. It's worth a 250.00 try vs 10k. JMO
The Boss
Aug 26, 2011 06:12 PM
rkbutz55
Jan 14, 2011 01:13 AM
Apalm84
Jul 23, 2009 01:15 PM
badbrad60
Oct 4, 2006 04:00 PM
kitsapcountychopper
25
Mar 19, 2004 08:11 AM
