6.0 thumping noise
I have an 06 f250 superduty, 6.0 . Last week I rolled into the the throttle up to about 95 and then backed off. After which it developed a thumping noise, not metal, more like an air thump in the intake. Not throwing any codes, still runs strong, pulls boost, etc. The motor does have 285,000. Any ideas.
Thanks |
Did you let off the throttle all at once. Have you ever had turbo fart
Yes, I let off the gas abbruptly, not sure on the turbo fart.
Turbo fart. Turbo going to need to be cleaned.
I took it to local mechanic, he hooked it up to the scanner, disconnected the turbo, noise was still there.?
Originally Posted by 9228.bobcat
(Post 15390399)
If you can't get this to recreate at any other circumstance other than getting high boost and then letting off the pedal abruptly, it is a turbo fart, nothing to be worried about. |
Is it thumping out of the intake even sitting there at idle?
Or does it only make that fluff, fluff, fluff or thump, thump sound after getting on it hard and then backing off quickly? Better yet, does it sound like this? If it does then it's normal because there's no blow off valve on these. |
Originally Posted by shultzaberger
(Post 15396618)
Or does it only make that fluff, fluff, fluff or thump, thump sound after getting on it hard and then backing off quickly? Better yet, does it sound like this? If it does then it's normal because there's no blow off valve on these. 6.0L Powerstroke SCT Tuned "Turbo Fart" - YouTube |
