Blend Door Foam Material
Old May 27, 2015 | 12:36 PM
mark460's Avatar
mark460
I'm in the process of fixing the cheap plastic hinge AC blend door on my 86 F350. I've search the forum here and found some that used like Home Depot foam, but was wondering if anyone has come up with any better foam material since then. I need to get like a piano hinge for the door, but was wanting to cover the door with some good foam stuff similar to the original Ford one.
Old May 27, 2015 | 03:28 PM
ctubutis's Avatar
ctubutis
I think I used packing foam from a computer monitor.
Take a look in a local hobby/art supply shop e.g. Hobby Lobby or Michael's.
Old May 28, 2015 | 04:46 PM
Diesel_Brad's Avatar
Diesel_Brad
I have used cap tape. The stuff that seals the cap to the pickup bed
Old May 29, 2015 | 12:35 AM
tempest411's Avatar
tempest411
You can get 1/8" or 1/4" thick foam rubber from your local Orchard Supply Hardware in what ever size you'd need, which works great for this use. I've also seen a different material at O'Reilly's sold as an oil absorbant foam mat which works great for the sliding door air vents on the non-AC trucks.
BigSpenda864
All Things Towing
May 22, 2018 07:45 PM
86Stepside
Oct 26, 2008 12:00 PM
greenterror
Jun 22, 2008 11:54 AM
lboogeylot
Dec 10, 2007 09:28 AM
