6.9 down. Need help asap
Old May 27, 2015 | 04:16 AM
Sdmusgrove0506's Avatar
Sdmusgrove0506
Hey guys. I got a phone call to help pull a buddy out who was stuck. Went over, hooked a chain. Put it in 4 high and gave a good couple yanks. On the third or 4th i went to put it back in drive and hit the gas and it revved but wouldn't move. I then couldn't move the shifter up to park and it wouldn't go up at all but down. I couldn't turn the truck off. I played with the 4wd and shifter. I ended up forcing it up into nuetral to turn off and get the key out. Now it won't turn over and the shifter is stuck. Any help or words of wisdom are greatly appreciated
Old May 27, 2015 | 12:09 PM
Mike1's Avatar
Mike1
Can you shift the T case in and out of gears? Did you check to see if your trans linkage got bent from maybe pulling too hard or maybe you jerked the truck to hard, twisted the trans and bound everything up?
chrissmallwood
Jun 30, 2010 01:07 AM
ts_stroker
13
Mar 12, 2008 07:53 AM
jdhv002
Bronco II
Sep 18, 2007 03:10 AM
HastyG
Jan 26, 2007 08:13 AM
94' Ford
Jun 17, 2004 08:33 AM
