Quick Question: My speedometer doesn't work and I'm not sure if I change trans or rear diff sensor?
I have a 2000 Excursion. 7.3L and 2 wheel drive.
The sensor I believe is the same for the top of trans and the top of the rear differential.
My code is P0500.
Which one do I change. Thanks!
My code is P0500.
The reason I am asking is because:
1) The speed sensor from O'Reilleys was dirty like it was previously used and returned.
2) I replaced the speed sensor on top of the rear differential and the speedometer doesn't work leading me to believe I need to change the sensor on the transmission or I have a defective replacement part.
3) I previously had the same code (P0500) on a different truck (4wd 1999 F250 Super Duty) with no speedometer and I replaced rear diff sensor and it immediately fixed issue.
5.4L to Freedom
1999 to 2016 Super Duty
15
08-21-2010 05:41 AM
