ok 2 questions. i found a thread on here before about how to clean injectors, i searched again and cany find it, can someone point me in that direction?
and second question can i use injectors off of a 1995 5.0 on a 1989 5.0 intake/ecu setup?
I simply used a 9v battery connected to a pigtail from Pep Boys to open the injector, and a rubber hose pushed over the inlet- I then filled it with fluid, and used compressed air to blow it through with... I also blew backwards through it a few times after removing it from the cleaner tub...
