np435 shifter
Old May 22, 2015 | 09:37 PM
drtnsnw's Avatar
drtnsnw
np435 shifter
Sorry for all the questions, but this clutch job is driving me crazy
So, finally got the clutch all in trans refilled and was going to put the shifter in and we ran into all kinds of problems!! WE could not get the arms to line up with the internals of the engine. It looks like the shifter got moved some time in the last week and now nothing seems to be lining up!!
Is the any kind of diagram as to how to align the arms? everything just seems to be out of whack!
Also, one of the plastic guides has gone missing off a shift fork. Is this something we can live without for a bit and is there a source for these?? Does summit carry them??
Thanks again guys, the kid is driving me CRAZY without his truck!!
Chris
Old May 22, 2015 | 10:13 PM
HIO Silver's Avatar
HIO Silver
The NP's top cover need not be removed to change the clutch. Why didn't ya just remove the shifter lever from the tower? That wouldda been waaaaay easier.
NP parts? Jeff's Bronco Graveyard.
Old May 22, 2015 | 10:16 PM
drtnsnw's Avatar
drtnsnw
because that is the way I have always done it. I will check Jeff's
Chris
Old May 22, 2015 | 10:29 PM
HIO Silver's Avatar
HIO Silver
.....Oy.....
Old May 23, 2015 | 10:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
See parts catalog pic below.
NP435 shift lever retainer cap (7220) has two notches, is retained to the shift tower with two pins (7221).
To remove this cap, it must be pressed down by hand and held down while turning it counter clock wise.
People unaware use pliers or channel locks to remove it, which tears out one or both of the notches. Not pleasant!
B8T-7220-D .. NP435 Shift Lever Retainer Cap / Obsolete
Closest sources to OP's residencia (NV) listed first.
MUSTANG'S ETC. in Van Nuys CA has 1 = 818-787-7634.
MCAULEY FORD in Patterson CA has 1 = 209-892-3341.
COLUMBIA FORD-LINCOLN in Longview WA has 1 = 360-423-4321.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 37 = 800-476-9653.
There are two different types of shift fork nylon inserts:
C2TZ-7C430-B .. 3-4 Shift Fork Nylon Insert-3/4" long x 1/2" overall width / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has 6 = 701-523-3257.
GREEN SALES CO. in Cincinnati OH has 52 = 800-543-4959.
D2TZ-7C430-B .. 1-2 Shift Fork Nylon Insert-3/4" long x 5/16" width x 1/4" thick / Obsolete
KIEFFE & SONS FORD in Mojave CA has 5 = 661-824-2568.
BELL-MCCALL MOTOR CO. in Hamilton MT has 5 = 406-363-2011.
GREEN SALES CO. has 84.
Old May 23, 2015 | 09:35 PM
drtnsnw's Avatar
drtnsnw
well, we got it today!! The shift forks had gotten out of sync and were causing all sorts of problems. Once we got the lever off we were able to move them back and forth till they matched up with the right places in the trans. as far as the nylon, once I pulled my fat head out of my dumb butt I remembered I had another 435 in the back so we robbed the parts out of it for the one in the truck. The boy is testing it now!!
It is amazing how good a fresh clutch feels
Thanks for all the info guys!!
Chris
Old May 24, 2015 | 09:13 AM
lafermedavid's Avatar
lafermedavid
ck out Novak info Bill passed on ,on the process of removing stick,should never be forgotten,counterclockwise
Old Sep 26, 2018 | 05:35 PM
Lalo Oropeza's Avatar
Lalo Oropeza
NumberDummy, I am looking for the replacement part for the Shift fork nylon insert for a DODGE F150 6 cyl. model 1982 4 speed + reverse.
Can you help me please?
Old Sep 26, 2018 | 05:36 PM
Lalo Oropeza
Hi I am looking for the Shift Fork Mylon Inserts for a Dodge F150 6 cyl 4 speed + reverse. model 1982.
Old Sep 26, 2018 | 06:32 PM
NumberDummy
Dodge F150? I don't know anything about Dodge's and F150 would be a Ford.
If you get the Dodge part number, I can look and see who has the part.
octaneforce
May 3, 2011 08:31 PM
russandirene
Jul 21, 2009 03:15 PM
Bill W
18
Apr 3, 2009 04:07 AM
rammstitch
Aug 18, 2008 07:19 AM
remmers
Apr 5, 2006 08:06 PM
