Fuel Filter Change Issue
Old May 22, 2015 | 06:12 PM
eutecticpt's Avatar
eutecticpt
I tried changing the fuel filter on my 1994 IDI Turbo tonight and ran into a snag. I had to remove the entire filter bracket because the filter was far too tight. When reassebling the system, the seal on the fuel outlet line got jamed into the flare fitting and now I can't get the seal dislodged from the fitting. Any tips on getting the seal out of the fitting? I pretty much think the is essentially destroyed.
Old May 22, 2015 | 06:56 PM
genscripter's Avatar
genscripter
Try a dental pick.
Old May 23, 2015 | 07:32 AM
IDIoit's Avatar
IDIoit
those "olives" are a royal pain!
this is exactly why i deleted every single one of them from my truck.
Old May 23, 2015 | 07:53 AM
bashby's Avatar
bashby
They are supposed to stay in the fitting. Are you replacing them? If so heat with a propane torch and they are easier to dig out.
Old May 23, 2015 | 08:20 AM
jayro88's Avatar
jayro88
Like others have suggested, heat and a pick.
Did you use a strap wrench or a belt to try and loosen the filter? I haven't found one that wouldn't come off this way.
Old May 23, 2015 | 08:47 AM
dropitlow88's Avatar
dropitlow88
little messier but if you don't have a strap wrench stab a hole through the side with a large screwdriver.
Old May 23, 2015 | 09:23 AM
eutecticpt's Avatar
eutecticpt
Tried a pick and was not able to get the darn thing out. Decided to just screw on the fitting and hope for the best. Truck was hard to start due to air in the line I suppose, but no fuel was leaking at the fitting after running the truck awhile. How do you get rid of the "olives"? Regarding removing the filter from the plate--I had to clamp the filter to a work bench and use a large channel lock pliers to break it loose--whoever changed it last really screwed up! From here on out, changing the filter should be a breeze. BTW-there was some gray sludge like material in the filter--glad I changed the filter. Thanks for the feedback.
Old May 23, 2015 | 10:46 AM
IDIoit's Avatar
IDIoit
olive deletion can be done with -6 AN fittings from the lift pump to the filter, and from the filter to the IP.
not cheap, but IMO better...
Old May 23, 2015 | 07:18 PM
vfelix702's Avatar
vfelix702
Idi do you have a pic of you olive delete?
Talyn
24
Nov 14, 2012 06:55 AM
caseydudem
Jun 2, 2010 06:39 PM
Rocketattack
Oct 17, 2009 09:26 PM
tjbeggs
Jul 1, 2008 03:01 PM
78f3504x4
Dec 8, 2006 06:07 PM
