Fuel filter seal
Old Jun 2, 2010 | 03:16 PM
caseydudem's Avatar
caseydudem
Fuel filter seal
I bought a fuel filter to change mine out, but it came with two seals. When I took mine out it only had one seal on it, the beveled one. I have only ever used one seal. Are you suppose to use both or just the one? When I used both it seemed to leak, but now that I took the one out it stopped. Thanks
Old Jun 2, 2010 | 03:32 PM
Ponyboychris's Avatar
Ponyboychris
Was the other seal a round o-ring? That's suppose to go on the groove on the filter itself before you install it into the housing?
Old Jun 2, 2010 | 03:56 PM
74baja's Avatar
74baja
I just did my fuel filter. It said there is a new design, they've eliminated the beveled gasket because of frequent confusion as to which way the bevel should face. The round O-ring goes around the bottom of the filter in the groove and the square flat gasket goes on top as the beveled one did.
Old Jun 2, 2010 | 04:34 PM
clintbonnie's Avatar
clintbonnie
There are two types of fuel filters... one with built-in lid and one without... .. the round o ring goes on the around the bottom.. without it, it will not filter properly.. I am not sure what the filter with the lid has as far as a seal... maybe it's built in.. I use the non lid type myself and it is supplied with 2 seals.. one for the lid and one for the bottom of the filter..
Old Jun 2, 2010 | 06:39 PM
danskool's Avatar
danskool
Go Bills !
What Clint Said.
Also here is a couple pics.. I use the the non lid type also.,
trat3gic
24
Jun 10, 2016 08:45 PM
sowaxeman
Apr 15, 2015 06:50 AM
mustange70
Offroad & 4x4
22
Dec 11, 2011 08:21 AM
mnmwhit
Jun 20, 2010 01:34 PM
Danimal1481
1983 - 2012 Ranger & B-Series
Feb 21, 2010 02:44 PM
