DNE2 Shift Motor Replacement Odd
Old May 20, 2015 | 09:39 PM
jayro88's Avatar
jayro88
So my DNE2 had started to not want to shift correctly. It shifted fine when cold, but once it got hot is would shift into LOW, but did not want to shift back into HIGH until it cooled down. I figured it was probably the shift motor getting week or a failing switch. I had already purchased a replacement motor and switch for it over the winter. I was just waiting until the weather warmed up to replace them. I figured today was as good a day as any.
My first plan was to just pull the unit and put i ton my work bench. However, the RTV I had used for a gasket would not let go. I tried a number of different methods and it refused to budge. So on to the next plan, replace the parts with the DNE2 installed. While this isn't overly difficult it is more of a pain than on the work bench.
The curious part is that when I removed the motor and switch it was not set up like all the others I had read about. There was no switch on the inside of the cover as shown in the pic
All my research had shown one of these on the inside of the terminal plate.
Then when I pulled the motor it had a type of circuit board with some relay on it. See the pic. The old motor is on the right and the new one is on the left.
I am assuming that the relays on the motor performed the job that the terminal switch I had seen did. It limited the amount of time that the motor would be energized in-case the other electronics failed and supplied a constant current.
I replaced the old motor with the new one. I decided to go ahead and put the switch in as well. The motor functioned correctly, but the switch did not.
The tab on the screw gear did not engage the switch correctly and allow it to open the circuit from one post and close the circuit for the other. Instead it appeared to complete both circuits and blow the 15 amp fuse in the DNE2 power supply. I removed the switch and wired it with the original posts/terminals. Since the DNE2 shift switch in the cab only energized the circuit when pressed and the control box switched leads every time it is pushed the DNE2 shift correctly without the new switch. The only danger is if the control box goes out and does not cut power to the shift motor after the button in the cab is released. In this case it would either fry the motor or blow the fuse. I have plans to eventually make my own simplified harness that should reduce any electrical gremlins. So far so good. The DNE2 unit is shifting quickly and consistently. Just though you guys might find this interesting.
Old May 20, 2015 | 10:35 PM
genscripter's Avatar
genscripter
I'm doing the same thing with all my stock and older aftermarket things. These late 80's electronics are garbage.
Old May 20, 2015 | 10:38 PM
RacinNdrummin's Avatar
RacinNdrummin
Did you put a gasket behind the access panel?
I had an issue with blowing fuses for a bit, but the studs on the switch were contacting the housing, causing a short and blowing the fuse... As soon as I made a gasket, no more issue...
Old May 21, 2015 | 07:34 AM
jayro88's Avatar
jayro88
I used RTV. There are plastic insulators shielding each stud/terminal. I made sure those were in good shape and installed correctly.
Not sure exactly what happened with the switch, but since I was an hour from having to drive the van to pick the kids up at school I just changed it back to the NO SWITCH configuration. So far everything is working flawlessly. My plan is to eventually get rid of all the DNE2 stock wiring and set up a simple circuit with a 2 way momentary switch to provide power to the motor.
Old May 21, 2015 | 07:40 AM
jayro88's Avatar
jayro88
Yep. It is always interesting when your driving down the road and stuff decides to flake out for a couple of seconds and then return to normal. I want to add some more 12v and a couple of 120v outlets to the passenger area of the van. I plan of adding a house battery and a secondary fuse box. Going to switch over all the non-essential/aftermarket items to it.....radio,dvd player, extra interior lights, etc.
Old May 21, 2015 | 11:10 AM
genscripter
You should look at Joshofalltrades van. He's running two 3G alternators powering two separate electrical systems.
Old May 22, 2015 | 07:57 AM
jayro88's Avatar
jayro88
I may have to do a search. I wonder how he mounted it? My first thought would be in place of the AC compressor. If that's the case I will keep my one alternator and AC.
Wasn't he needing the extra alternator to power tools for work and maybe a small air compressor?
Padlock
Aug 4, 2014 11:12 PM
DillonZ81ford
Feb 13, 2010 01:22 AM
Localsalt
1978 - 1996 Big Bronco
Sep 12, 2009 11:27 AM
veritas
Dec 19, 2008 08:48 AM
highboy390fe
Nov 21, 2008 10:36 PM
