Sponsored by: Real Truck
odd 4r100 problem
Old May 17, 2015 | 03:10 AM
63falconfutura's Avatar
63falconfutura
odd 4r100 problem
Hi i have a 2004 f250 5.4l w 4r100 and it seams to loose its gear or down shift only when i take a hard right turn i took it to a trans shop and it shows no codes and at this point i am very confused any help or sugestions would be great thanks
Old May 17, 2015 | 08:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low transmission fluid can do this. Check the fluid with the transmission warmed up and the engine idling in park.
Old May 17, 2015 | 05:46 PM
63falconfutura
checked the fluid and did a filter change very little on the magnet fluid is some what dark and a little burnt smelling but not to bad over all i thought it might be a dislodged filter but that was not it
Old May 20, 2015 | 11:20 AM
63falconfutura
no other ideas i am grasping at straws at this point i have a hard time thinking its mechanical but can not find anything electrical the local trans shops say low fluid but its good on the stick warm idling
Old May 20, 2015 | 11:25 AM
andym's Avatar
andym
Transmission fluid isn't supposed to be dark or burnt-smelling at all. Change it out ASAP.
Old May 20, 2015 | 04:23 PM
Mark Kovalsky
You say not bad over all, but what you wrote says the fluid is completely destroyed. That often indicates damaged clutches.
Old May 20, 2015 | 04:29 PM
63falconfutura
if it was a c6 i would not think twice about the fluid it looks and smells more worked that destroyed at this point i think it is down shifting to 2nd gear in the corner but do not know why
Old May 21, 2015 | 05:48 AM
redford's Avatar
redford
FTE Leadership Emeritus
The members here are trying to assist you, but if you keep arguing with them when they try to help, no one else will want to offer help.
Old May 21, 2015 | 05:02 PM
Mark Kovalsky
Maybe you're right, but in my experience once the fluid is dark and has ANY burnt odor the fluid is completely destroyed.
Old May 22, 2015 | 06:07 AM
63falconfutura
I found my problem there was a wire from the manual range switch that was rubbed through above the fuel filter it set a code yesterday outer cover on the harnes looked fine but the flex in the cab mounts and frame would push the frame through the split in the cover and ground out the wire thanks for all the ideas 2 trans shops and hours on here before i could find it. Just wanted to add THANK YOU FOR ALL THE GOOD INFO ON HERE AND THIS SITE!!!!!!
dan8052
Aug 16, 2013 01:23 PM
pcf_mark
22
Jan 20, 2010 03:39 PM
orion_134
26
Jul 14, 2008 07:47 PM
c00nhunterjoe
Jul 20, 2007 09:06 PM
ExplorerSp0084
Sep 26, 2003 04:40 PM
