Trans temp..am I screwed?
Old Jun 18, 2008 | 04:29 PM
orion_134's Avatar
orion_134
My buddy borrowed the truck to tow his car on the trailer. He told me that he noticed it shifted funny and saw that the temp was 200+. He pulled over and let it cool down to 200, then finished the 5 minute drive home. He then hopped on the interstate and drove back to where I was and told me all this. I'm sure when he got on the interstate, it dropped back down and when I got it, the temps were 170-180. Now...1st and 2nd gear flareup after about 2k rpms and want to hold the gear to redline unless I blip it and let off, it will then shift (trans temps 150-165). Once the converter locks up all is good. I smelled the trans fluid, it only has a slight smell of non-normal, so it shouldn't be that bad.
I'm going to let it sit for a few hours and go back out because I have to drive to class.
Am I screwed and have burnt/glazed bands or do I just have deteriorated fluid and need a flush?
Thanks,
Jesse
Old Jun 18, 2008 | 04:34 PM
03F2507.3's Avatar
03F2507.3
I would say start with draining the fluid and add a quart of Lucas trans additive along with a new filter. I had a sluggish shift from 3rd to OD and drained fluid, changed filter and refilled and have had no problems since. I know I didnt get all the fluid out, but I spun the torque converter and ended up getting about 10 quarts out. Good luck
Old Jun 18, 2008 | 04:37 PM
Smokin''s Avatar
Smokin'
Smokin
Thats why I dont let ppl borrow my truck.
What does slightly non-normal mean? I'd do a fluid change, get some fresh fluid in there.
Old Jun 18, 2008 | 04:47 PM
That_Guy's Avatar
That_Guy
When mine trans went it was shifting like you said and the fluid didnt smell burnt either.... I know that might not be good news for you but try to pull some codes and see what you come back with. I would try the new fluid and filter first though
Old Jun 18, 2008 | 05:54 PM
aklim's Avatar
aklim
Please tell me he pulled over and kept the truck idling.
I think the trans is going south if the fluid is burnt
Old Jun 18, 2008 | 08:26 PM
orion_134's Avatar
orion_134
He said he pulled over but didn't give it enough time to cool off thinking that he needed more airflow through the cooler...
Old Jun 18, 2008 | 08:53 PM
jhand124's Avatar
jhand124
What temp did it get to? He must of got it to 230-240, just above 220 would be the limit that I would pull over and stop, and leave it idling.
Old Jun 18, 2008 | 09:12 PM
orion_134's Avatar
orion_134
I think it was around there, but he said just over 200...
Old Jun 18, 2008 | 09:17 PM
jhand124's Avatar
jhand124
200 towing isn't way out of line if it's 90° out, but if it's not acting the same as it was before he borrowed it, it may have been hotter or it was just time for the TC to give up. How many miles are on it?
Welcome to FTE
Old Jun 18, 2008 | 10:37 PM
MTDewX's Avatar
MTDewX
How does he knows it was shifty differently. does he drive the truck often to know???
at least he was looking at the gauges. I know some folks that dont care and just drive. so I dotn let many people drive my truck, cause some thing is never right when I get it back.
Old Jun 19, 2008 | 12:28 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
This is where the "you break it you bought it" rule comes in to play
Try the additive method mentioned and tell us what you get.
Old Jun 19, 2008 | 12:31 AM
UP_There's Avatar
UP_There
it's things like this that REALLY test a friendship
Old Jun 19, 2008 | 12:35 AM
HighOctane's Avatar
HighOctane
PMS: an obsession
Exactly! I had dammage done to an old truck of mine by a very close buddy when he needed to do some yard work. Also, I let the warden borrow my PSD the other day, and wouldn't you know it, my alarm pager digital face is all messed up. I have it for a half a year, no problems, she uses it for a few hours, dammage done. Go figure. NO MORE !
Old Jun 19, 2008 | 02:33 AM
AustinS's Avatar
AustinS
Flush it out with new fluid and see where you stand.
My '01 got up to 215-220 towing real heavy up the mountains 5yrs ago. I flushed it out with fresh fluid the next day, and have kept up with every 30K since and no problems as of yet. I tow at least 4 days a week with it too.
Hopefully your tranny escapes serious trouble for your wallet and your friendship's sake.
Austin
Old Jun 19, 2008 | 07:19 AM
aklim's Avatar
aklim
Every time I have had slightly burnt fluid in my transmissions, they were on the road down.
