Another split transfer case
Old May 16, 2015 | 07:18 PM
cabloom300's Avatar
cabloom300
My buddy was on his way from PA to SC and on the way this happened. I remember awhile back that the front cardon joint Gets old on the front drive shafts and causes vibration enough for the case to split? The hubs were not engaged at the time. Any other ideas?
Old May 16, 2015 | 08:00 PM
snknby123's Avatar
snknby123
Sorry for your friends misfortune. There is a thread on this a couple months ago on split cases. Apparently, Ford changed the fluid type to XL-12 I believe. Search and you will find lots of info.
What fluid was your buddy using? Mercon V? Question: If the hubs were not locked how can the worn out cardon joint on the front shaft be the cause?
Old May 16, 2015 | 08:06 PM
clem1226's Avatar
clem1226
How many miles on it?
At around 400k I started to get a rumble out of mine, drained the fluid and strained it through some blue shop paper towels and found a bunch of bearing/race chrome flakes in the fluid.
What kind of condition was the carrier bearing in?
Old May 16, 2015 | 08:07 PM
Thomas White's Avatar
Thomas White
FTE Thread https://www.ford-trucks.com/forums/1...ners-read.html
Old May 16, 2015 | 09:03 PM
cabloom300's Avatar
cabloom300
Miles are somewhere around 220k. I'm not sure on what oil was in it because he just got the truck a couple months ago.
Old May 17, 2015 | 12:44 AM
carltonwebb's Avatar
carltonwebb
We had one at work just blow up like that cause by bad universal in front driveshaft.
Old May 17, 2015 | 07:45 AM
cabloom300's Avatar
cabloom300
Also he said the other night that it was vibrating badly long before it ever went. He would stop and see nothing wrong and kept driving. I find it hard to believe that the fluid could cause these to break
Old May 17, 2015 | 06:07 PM
clem1226's Avatar
clem1226
I personally am not sold on the merconV causing the issue either. There is no real evidence other than the one u tube video that was posted in this thread earlier. That being said its dirt cheap to buy 2 quarts of transfer case fluid from ford.
I bet he lost a bearing.
What year is the truck? Mine is a 2000 and as I said earlier I caught mine before it grenaded but it was on its way.
Old May 17, 2015 | 08:27 PM
cabloom300's Avatar
cabloom300
I think it's An 02. I'm not sure the condition of the carrier bearing though. Would that cause an issue in the front even though it is on the rear?
Old May 20, 2015 | 10:21 AM
Fat Diesel's Avatar
Fat Diesel
I've always used Mobil 1 SYN AFT.
Old May 20, 2015 | 10:34 AM
clem1226's Avatar
clem1226
My comment about "loseing a bearing" should have read " lost a bearing in the transfer case"
Just spit balling but.....
Bad carrier bearing introduces small vibration in to the drive train directly affecting the out put bearing in the transfer case. The output bearing begins to lose the plateing on the race and bearing and all the metal gathers in the bottom of the case and bathes the front output bearing in grit accelerating its wear and generating heat. The front output bearing seizes and boom, Pics posted on FTE.
I have no idea if this scenario resembles reality but it makes sense to me.
Old May 22, 2015 | 07:17 AM
tjmike's Avatar
tjmike
What is the condition of the front drive shaft (u-joints and double cardan)?
Old May 22, 2015 | 09:21 AM
trackspeeder's Avatar
trackspeeder
Same here. Aint blown up yet.
texrdnec
May 10, 2017 06:40 PM
fishbones182
Dec 30, 2015 07:24 AM
Kep4
6.7L Power Stroke Diesel
Aug 2, 2014 12:15 PM
steve381
Bronco II
Mar 31, 2005 04:19 PM
stepside64
Mar 26, 2004 11:00 AM
