Bronco II Ford Bronco II
transfer case fluid
Old Mar 25, 2005 | 01:24 PM
steve381's Avatar
steve381
transfer case fluid
just changed the fluid in the transfer case or at least drained out all that would come out only took little more than a quart to go back in and most of that was probably run off this sound right?
Old Mar 26, 2005 | 07:59 AM
bigswede's Avatar
bigswede
You should be OK. I replaced my transfer case fluid with synthetic tranny fluid. Check out therangerstation.com for tech info.
Old Mar 26, 2005 | 10:56 PM
Monty06's Avatar
Monty06
sounds to be in between you might need a little more
syn fluid works sometimes depends on usage.
Old Mar 31, 2005 | 09:00 AM
raveng60's Avatar
raveng60
speaking of fluids... what kind of oil you put in the differentials? i got confused with all this friction modifiers stuff. do you even need any and how hard is it to do it yourself? i got a '89 4x4 5 speed with auto hubs. any info will be apresiated.
Old Mar 31, 2005 | 04:19 PM
Ken00's Avatar
Ken00
Hypoid gear oil goes in the rear, check your owners manual for the specific weight. You only need the modifier if you have a posi.
