A/C only works when moving
Old May 14, 2015 | 11:15 AM
jfowler1's Avatar
jfowler1
Any one have an idea, and more importanly a price for this listed fix? My A/C works fine when I am moving, but when i come to a stop it does not come out cold.
Old May 14, 2015 | 11:18 AM
sessland's Avatar
sessland
I had this exact issue in a previous vehicle a while back.
Driving down the street it would blow cold but if I came to a stop light or standing still in traffic it was just blowing air.
If pressed for an answer I believe it was diagnosed as a bad compressor but my memory isn't 100% on it.
Old May 14, 2015 | 11:26 AM
LivingLarge's Avatar
LivingLarge
Could be your compressor is starting to go, but check this first...
Old May 14, 2015 | 11:32 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Also check your fan clutch. If it is not pulling enough air through the condenser, it cannot cool efficiently. Are you running warmer than normal?
Old May 14, 2015 | 11:51 AM
JuanHuevos's Avatar
JuanHuevos
This ^^^ Fan clutch is notorious for this issue.
Old May 14, 2015 | 12:09 PM
1NiceHarley's Avatar
1NiceHarley
Fan Clutch was the problem on mine also.
Old May 14, 2015 | 12:51 PM
pgguru's Avatar
pgguru
and if not the clutch check that the rad/trans cooler/intercooler/ Rad are not getting clogged with bugs, dirt, and road debri
I once found a plastic bag stuck in mine.
Old May 14, 2015 | 08:37 PM
Excurvelle's Avatar
Excurvelle
Fan Clutch.
Old May 19, 2015 | 09:01 AM
jfowler1's Avatar
jfowler1
Its not running hot. Does anyone know what a Fan clutch will cost me, part and labor? I typically go to the dealer to have work done. Its an 04 Diesel 4x4
Old May 19, 2015 | 09:15 AM
Apocalypse's Avatar
Apocalypse
Wifes Highlander is doing the same thing... Takes forever to cool down too, should I replace the compressor?
Old May 24, 2015 | 11:10 PM
wpnaes's Avatar
wpnaes
I recall it being $172 and it takes an hour to R&R. https://www.ford-trucks.com/forums/1...placement.html
Originally Posted by pgguru
and if not the clutch check that the rad/trans cooler/intercooler/ Rad are not getting clogged with bugs, dirt, and road debris
http://www.ebay.com/itm/151672871687?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Jun 5, 2015 | 09:11 AM
jfowler1's Avatar
jfowler1
The problem was the whole ac unit pretty much. New condenser, orifice tube and dryer. Ford wanted 1600 to fix. My local supercharged me a bit under 1000.
Old Jun 5, 2015 | 09:54 AM
Archion's Avatar
Archion
$1000 is about average for a system replacement these days at a shop. Be glad it's not an import, those little Diesel Kiki compressors get mighty expensive. Glad you got it sorted out.
Old Jun 5, 2015 | 09:57 AM
FLO98's Avatar
FLO98
I was about to chime in with no help and say "Isn't that why these things came with a 44 gallon tank, so that you don't have to stop moving?" Then I saw you got it fixed. So never mind... glad you got it figured out, but it sucks that it cost you $1000 to do so.
Old Jun 5, 2015 | 01:17 PM
05MilMachine's Avatar
05MilMachine
Did you get/need a new compressor?
tracyclifton
Jun 11, 2015 11:52 AM
fifty-two_f1
Aug 22, 2011 09:16 PM
Samuelito
2009 - 2014 F150
Jul 27, 2011 05:28 AM
TR6
Jul 25, 2009 04:57 PM
krewat
Aug 22, 2005 08:22 AM
