coolant question
Old May 12, 2015 | 04:00 PM
bobv60's Avatar
bobv60
coolant question
Been finding conflicting info when I search this subject. When I got this 2003 6.0 I changed the coolant. I thought I got the right stuff but now I am not sure. I got Zerex extended life coolant, Cat and Cummins spec for heavy duty diesel trucks (Red/Purple). Now I am reading GO-5 spec only. The egr cooler has been removed, if that makes a difference.
THANKS
Old May 12, 2015 | 04:05 PM
WatsonR's Avatar
WatsonR
I'm running the same stuff, ELC extended life coolant, red color, mine is made by Fleet Charge.
Old May 12, 2015 | 04:18 PM
npccpartsman's Avatar
npccpartsman
THANKS
The Zerex red stuff is what I'm running. Be sure and get the concentrate and NOT the 50/50 mix.
Old May 12, 2015 | 05:17 PM
bobv60's Avatar
bobv60
Thanks, I called Zerex today and they said that it is fine, the GO-5 is the factory spec and that is what SHOULD be in it. But the elc will work fine.
Old May 12, 2015 | 05:38 PM
bobv60's Avatar
bobv60
Yes, I used the non deluted and used distilled water
Old May 12, 2015 | 10:06 PM
brandonrr's Avatar
brandonrr
what's wrong with the 50/50 mix? Wouldn't that eliminate the possibility of having an incorrect mixture ratio?
Old May 13, 2015 | 06:46 AM
WatsonR's Avatar
WatsonR
if you used distilled water to flush the system, that would leave a certain amount behind that couldn't be drained. Adding 50/50 would then make the mixture about 75/25 water to coolant. Using pure coolant makes it closer to 50/50 and then just top up using water to finish.
You could flush with 50/50 and then it won't matter.
Old May 13, 2015 | 08:06 AM
mohoneywell's Avatar
mohoneywell
you're paying for them to water down to your coolant......
Old May 13, 2015 | 01:33 PM
Tampa250's Avatar
Tampa250
This- concentrate is about the same money as the 50/50 so you're really getting 2 gallons worth of coolant for your system when you buy a gallon of concentrate.
Old May 13, 2015 | 02:11 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
50/50 is just the basic specification, if you live in the Great White North you need to actually read the bottle and put in the correct concentration for temperatures that you see.
Zerex G-05 can go up to 70% coolant/30% water for maximum freeze protection of -90*f, using 50/50 only goes to -34*f.
Old May 13, 2015 | 04:18 PM
npccpartsman
When you flush your system there's no way to get all the water out. If you just drain the radiator you leave 50% (3.5 gallons) of the system capacity in. As previously stated if you refill with 50/50 mix you actually get a 75/25 water to coolant ratio.
Old May 13, 2015 | 04:25 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Go-5 coolant is a low silicate formula similar to the Ford "gold" that is factory fill in these trucks. Because of suspected issues with silicate fall out (precipitation) clogging the oil cooler and causing issues with EGR cooler, many prefer to use a completely silicate free coolant that meets the CAT EC-1 standard. Many trucks have logged many miles with the low silicate coolant without issues but the silicate free stuff eliminates any possibility of having those issues.
I agree you must have concentrated coolant not 50/50 premix to get the proper concentration when you service it.
Total cooling system capacity including the degas bottle is 27.5 qts. If you drain the radiator by the lower hose or the draincock you'll remove 1/2 the system capacity--about 14 qts. Therefore it takes 14 qts of 100% coolant added back to the system to get a 50/50 mix if you do a complete flush and fill.
troy676
Mar 25, 2014 10:43 AM
Subzero68
Dec 18, 2013 08:30 PM
jdhart73
May 24, 2012 04:43 PM
merlins'92f250d
Feb 25, 2012 10:28 AM
Byrddog
Jun 17, 2004 11:09 AM
