Help
Old May 10, 2015 | 05:02 PM
dld63's Avatar
dld63
Help
I have a 99 F 250 7.3. It runs fine at idle even for a long time. When I drive around the block a couple of times it will start chugging and lose power and shut off. I have been mixing fryer oil with the diesel. I changed the fuel filter, oil change, crank sensor and fuel pump. I added 15 gallons of diesel and diesel treatment. Pulled fuel filter and bowel is full I'm not sure where to look next.
Old May 11, 2015 | 10:17 AM
Pikachu's Avatar
Pikachu
You should probably put a fuel pressure gauge on it and see what it does at wide open throttle, under load.
Webasto 9.1KW
35
Feb 18, 2013 10:38 AM
JimEG
Jun 24, 2012 08:36 PM
the almighty schmuck
Nov 7, 2011 09:34 PM
jayw64
Oct 23, 2007 02:09 AM
larry1968
Sep 23, 2007 10:14 PM
