let me pick your brain
i drained the fuel water seperator but didnt get a good look at the filter. then i removed the upper filter which was filthy, cleaned it with some gasoline and put it back in. the truck ran better on the way home but still has a loss of power above 2000rpms. i am getting no codes and icp pressure seems fine.
i plan to change the fuel filter later this week after i finish running out this tank of fuel. so basically i am asking do yall think that seems right and fresh fuel filters will fix the problem? and do any of those statements that i heard about farm diesel seem accurate? and if so where would i find the sensor so i can clean it or change it? i dont have a fuel pressure gauge or anything to measure egt's but i do have a scan gauge 2 in the truck.
wouldnt the egt's be really high with running 20 lbs of boost for 30+ miles? could that have caused the truck to start stumbling and running real bad because at that point i slowed down to 60mph until i could get off the interstate and shut it down for a few minutes?
thanks in advance
sorry to hear u got a prob.
be careful ur not boosting too much as tat may blow a headgasket. it sounds like injector stiction from tat farm diesel thing.
might also be ur oil cooler or egr cooler or both. if u have a scangauge, u can monitor the ect & eot spread to know if oil cooler or egr cooler is dead. in tat case, if u gotta change one, change both.
wif regards to ur fuel filters, i wouldnt jus clean them to put them back, especially the secondary fuel filter (filter on top of the engine). i would change both of them everytime i loosened them. moreover, since ur vehicle is a 6.0, it is more sensitive to GASOLINE than the 7.3. on top of that, u cleaned it in gasoline and put it back. tats a no no. basically, wat u did was contaminate the fuel system wif gasoline. i dunno how much gasoline got soaked in there, but if too much, it may overwhelm ur fuel. also, where ur fuel filters go, is exactly where the diesel fuel gets cycled thru the entire engine. oh boy, i hate to be the bearer of bad news, but it sounds like contamination somewhere.
ur car is not gonna like u for this. it's sensitive. it hates gas. it loves only diesel. might be why it burped on u.
i would change the fuel filters out now. if there's a significant amount of gasoline in the system, i'd flush it out to purge it clean of gasoline.
the ect & eot is supposed to be a 15 degree spread for regular driving, and even for hauling. some might experience slight difference.
dont worry. the good fellas will soon chime in. best of luck. we're all here for u.
You need to change the filters now. How often do you change them and what brand filters do you use?
The first thing to do when buying a used vehicles is to change the filters IMO. The reason the design was changed on the primary filter (added o-ring) was to prevent filter bypassing. As others have said, injectors are expensive and poor filter maintenance practices (re-using filters and/or going too long between changes or even using aftermarket filters) can be the quickest way to rack up thousands of dollars in repair bills.
If you travel out-of-town much (ie no fun being stranded out-of-town w/ a no-start), I would take it in and have a dealership do a cylinder contribution test.
Unless I'm miss reading where your from...it looks like you call New Orleans, LA home. Which case you'd want to get in touch with the Louisiana chapter:
Louisiana Chapter - Ford Truck Enthusiasts Forums
ive only had the truck for a few months and all filter and fluid changes were in the plans to be finished by thanksgivivg. i will be doing coolant this week.
id love to bring it in to do a cylinder contribution test but its my only ride for the moment so that will have to wait.
it does have a cold start problem as in it takes several seconds to start even in high ambient temps. ive checked ficm and battery voltages plus the icp pressure is good
