tires lean out
Old May 9, 2015 | 10:13 PM
turbodeisel's Avatar
turbodeisel
Originally Posted by Chevy_Eater
That rear looks stock. See that extension on the inbound side of the blocks? Those are the stoppers for the rubber frame blocks, uh, when it had them.
So I'm missing rubber frame blocks.?
Old May 9, 2015 | 10:43 PM
turbodeisel
Wow why why would they take them out.lol
Old May 9, 2015 | 11:36 PM
tecgod13's Avatar
tecgod13
Uhhh... wow! not sure where you found that picture, but the truck is FAR from stock!
Looks like there is a block under the stock spring block.
The rubber things there are airbags.
Those shocks are some fancy ones with a reservoir, also not sure if they've been moved. Judging from the disc brakes thats a newer truck.
Generally people don't take out the rubber bump stops. Over time they break down and fall off.
Old May 10, 2015 | 12:51 AM
turbodeisel
Yea it's just an example pic mine is a 90 I was just showing what I was missing.
Old May 10, 2015 | 09:29 AM
Royson12's Avatar
Royson12
Here are a couple of pics of that shackle reverse kit halfway installed. Please excuse the rust. I just now had time and place to get going on it again. You will need the extended center pivots as well. If you lift it, it will camber the tires without them. Got to do a little welding to install them. Wasn't bad.
Old May 10, 2015 | 09:37 AM
Chevy_Eater's Avatar
Chevy_Eater
Yeah, but you are not missing those, those are air bags that someone added to that truck. What you are missing is just a couple of small rubber blocks that mount to the frame that the stoppers rest against during overload.
And Techgod's right, they more than likely wore off than were removed.
Old May 10, 2015 | 09:42 AM
Chevy_Eater
Something along the lines of these:
(Generic picture off of web)
Old May 10, 2015 | 01:25 PM
turbodeisel
Oh okay gotcha ..man I am having a hell of a time realigning the center pin in leaf springs any idea how to do this?
Old May 10, 2015 | 03:11 PM
Realslowww's Avatar
Realslowww
When I back mine in the tires lean in at the top. How much front end work ?
Old May 10, 2015 | 05:26 PM
tjc transport's Avatar
tjc transport
i ain't rite
there is no easy way, you just need to take your time. i have found it helps to set the ubolts loose so the axle just barely touches the springs, then move the axle forward/back by the wheel until you fell it seat in the hole.
Old May 10, 2015 | 05:28 PM
tjc transport
i ain't rite
probably none. you don't go by where the wheels sit after reversing. you go by how they sit after going forward and straight for at least 10-15 feet.
Old May 10, 2015 | 06:56 PM
Realslowww's Avatar
Realslowww
Thanks sir, but I believe there are a few issues with my front end.
Old May 10, 2015 | 10:17 PM
  #28
tecgod13's Avatar
tecgod13
Can you elaborate on that? Have you done any troubleshooting, or just guessing? Handling issues? Abnormal tire wear? Funny noises?
Like Tom said, the way the suspension is setup, the tires can lean after backing up, that doesn't mean there is a problem, its just the way it is.
sparrish65492
Sep 10, 2011 11:04 PM
mq1shooter
Feb 28, 2010 01:27 PM
1wildman67
1978 - 1996 Big Bronco
Aug 6, 2008 09:03 PM
safehaven
Feb 26, 2008 02:16 PM
lud04X
Feb 22, 2008 02:00 AM
