1978 - 1996 Big Bronco
front suspension problem
Old Aug 1, 2008 | 08:28 PM
1wildman67's Avatar
1wildman67
When I am backing up in my '93 bronco, the front tires will stradle out, pull the bronco forward and the tires will stand straight again. I have lifted the front and pulled on both tires with my hands looking for ware and things look good. Whats the problem or where do I look next?
Old Aug 2, 2008 | 09:36 PM
prepwd's Avatar
prepwd
i forget the name,maybe axle pivot bushing. with tires stradled out, look at axles from front and back to see if bolts at "sissor connection point" look off center. When mine were bad it took a while before the tires started wearing "inner threads".
Old Aug 3, 2008 | 08:40 AM
drunkdave's Avatar
drunkdave
wildman,
your front end needs to be alined. I went through the same thing after I lifted my 89. The Camber is way off. I forget the exact name of it, but it but it is a bushing.
Old Aug 6, 2008 | 09:03 PM
fleetbob1's Avatar
fleetbob1
hockey puck,camber bushing ---goes over the upper ball joint
sets camber and some caster
check your ball joints, axle pivot bushings and radius arm bushings first
